Can't find it either, maybe not released yet.
Did you get any chance to measure the noise under high load with your DSO?
I saw in that other video that noise can go up to 100mVPP, but more as a verification.
I also wonder if the switched power supply itself is part of that noise aspect, or does it all come from the buck converter. Does that even work that way? (noise in->noise out) (have you measured that?).
If it comes from the internal psu module the noise could be lowered with some capacitors.
I'm in the process of choosing a dual bench power supply (budget about €250,-) and I cant decide between 2 of these or a Korad KA3305P
The Korad is linear so probably less noise and is about the same cost. The big disadvantage with the Korad is that it's big and bench space is always limited.
And of course it doesn't have a display mode where you see a graph. That's only via the software.
I also like the Ah meter on the rd6006. Does that also work in non battery mode? (I believe I did saw it work).
And if so, when does it reset? when you turn the output off and on again?
And is it possible to not have that Ah meter periodically change on the display with temp and Wh? (I dont think so)
What I don't understand with the video review of SDG is that he calls it a "Programmable Bench PSU"
But what exactly is programmable? I don't think that you can program it to give different voltages or currents for certain periods of time. Like you can with for instance the korad or a siglent spd3303. I thought that that made it a "programmable" PSU?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
