Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 418565 times)
0 Members and 29 Guests are viewing this topic.
Offline 999cgm
Re: RuiDeng Riden RD6006 DC power supply
« Reply #550 on: January 19, 2021, 04:16:15 pm »
n00b q: what / how is ORP used?
The following users thanked this post: AaronR
Offline AaronR
« Reply #551 on: January 19, 2021, 04:31:53 pm »
Good question. I'm sure it stands for 'over resistance protection' Maybe something to do with battery charging?
Offline 999cgm
« Reply #552 on: January 19, 2021, 05:11:12 pm »
Yep , it has to be related to Resistance.. there was an earlier post where a test was done with a ORP set to 9Ohm . Re-reading now makes more sense..
Now what happens if we set ORP delay = auto ?
Offline UniSoft
  • Country: kz
« Reply #553 on: January 19, 2021, 06:33:52 pm »
Delay until the output voltage stops rising. (Same delay used for UVP (Under voltage protection)).
« Last Edit: January 19, 2021, 06:36:21 pm by UniSoft »
The following users thanked this post: 999cgm
Offline sotos
  • Country: gr
« Reply #554 on: January 19, 2021, 09:19:20 pm »
Ooops a little confused here, what is the difference between rd60062 and rd60061 I have tried both and at first, look the same.
Offline UniSoft
  • Country: kz
« Reply #555 on: January 19, 2021, 09:28:23 pm »
RD60061 is the very first revision and it has never been sold outside of China.
P.S. Today will come my RD6006P (RD60065)
« Last Edit: January 19, 2021, 09:31:47 pm by UniSoft »
The following users thanked this post: sotos, AaronR
Offline AaronR
« Reply #556 on: January 20, 2021, 05:02:38 am »
So I'm trying to figure out how to graph this excel output from an RD6018 driving a 12 volt inverter with a 200 watt incandescent bulb as a load.
I managed to get some graphs but I can't figure out the correct way to do it. The one graph I did get was both upside down and flipped horizontally vs time and amplitude.
Offline UniSoft
  • Country: kz
« Reply #557 on: January 21, 2021, 07:02:31 pm »
RD6006P...
ADC: Dual 24-bit TM7707 (didn't found English datasheet).
DAC: Dual 16-bit DAC8562
« Last Edit: January 22, 2021, 02:48:06 am by UniSoft »
The following users thanked this post: Cliff Matthews
Offline end0101
« Reply #558 on: January 23, 2021, 11:10:45 pm »
rough machine translated to english tm7707 datahseet, hope posting this isn't against terms
« Last Edit: January 23, 2021, 11:13:30 pm by end0101 »
Offline Blake
« Reply #559 on: January 24, 2021, 04:51:52 pm »
Where can you buy the RD6006P?
Offline UniSoft
  • Country: kz
« Reply #560 on: January 24, 2021, 05:14:01 pm »
now only taobao... they still not sell worldwide.
Offline AaronR
« Reply #561 on: January 24, 2021, 05:26:42 pm »
I was confused about the RD6006P, I didn't see any explanation of what it is compared to an ordinary RD6006, so now I see the 'P' designation must stand for precision? because they added more digits to the voltage and current readouts. Are there any other differences?
Did I miss a post where this is all explained??
« Last Edit: January 24, 2021, 05:31:11 pm by AaronR »
Offline UniSoft
  • Country: kz
« Reply #562 on: January 24, 2021, 06:30:36 pm »
This is a hybrid: Switch mode + linear
Firmware support setup colors (copied from my firmware)
Can setup CutOff current and CutOff temperature.
I made a comparison table
Model:RD6006RD6006P
Input voltage range:6-70.00V7-70.00V
Output voltage range:0-60.00V0-60.000V
Output current range:0-6.000A0-6.0000A
Output power range:0-360W0-360.00W
Input voltage measurement resolution:0.01V0.01V
Output voltage setting measurement resolution:    0.01V0.001V
Output current setting measurement resolution:     0.001A0.0001A
Battery voltage measurement resolution:0.01V0.01V
Input voltage measurement accuracy:±(1%+5 digits)±(1%+5 digits)
Output voltage accuracy between setting and measurement:±(0.3%+3 digits)±(0.5%+4 digits)
Output current accuracy between setting and measurement:±(0.5%+5 digits)±(1%+6 digits)
Battery voltage measurement accuracy:±(0.5%+3 digits)±(0.5%+3 digits)
Automatic cut off current value when charging:10mAselectable
Output ripple typical:100mV VPP10mV VPP
Working temperature range:-10℃~40℃-10℃~40℃
External sensor Temperature detection range:-10℃~100℃/0℉~200℉-10℃~100℃/0℉~200℉
External sensor Temperature detection accuracy:±3℃/±6℉±3℃/±6℉
Constant voltage mode response time:2ms(0.1A-5A Load)2ms(0.1A-5A Load)
Constant voltage mode load regulation:±(0.1%+2 digits)±(0.1%+2 digits)
Constant current mode load regulation:±(0.1%+3 digits)±(0.1%+3 digits)
Capacity measurement range:0-9999.99Ah0-9999.99Ah
Energy measurement range:0-9999.99Wh0-9999.99Wh
Capacity and energy statistical error:±2%±2%
Buck working mode:Voltage drop >1V and >10%Voltage drop >10% x VOUT + 2V
Cooling fan start condition:Vout>40V or Iout>4A or SysTemp>45℃Iout>4A or SysTemp>45℃
Cooling fan shut down condition when working:Vout<40V and Iout<3.9A and SysTemp<45℃Iout<3.9A and SysTemp<45℃
Over temperature protection:SysTemp>80℃SysTemp>80℃
Screen brightness setting:0-5(6 level in total)0-5(6 level in total)
Screen:2.4 inch color HD display2.4 inch color HD display
Weight(with package):About 0.58kgAbout 0.62kg
Product dimension:167*81*65mm167*81*65mm
The following users thanked this post: BravoV, 4cx10000, ledtester
Offline Pukker
« Reply #563 on: January 24, 2021, 07:40:02 pm »
Switch mode + linear, so less ripple, great with an toroidal, bridge rectifier and big Cap.
Firmware support setup colors (copied from my firmware) Whow,
send them a bill.
Offline UniSoft
  • Country: kz
« Reply #564 on: January 24, 2021, 08:21:46 pm »
If anyone interested...
Using a couple of 100W COB LED as a load,
11.8V 6A
11.2V 3A
10.6V 1A
10.2V 100mA
Using DL24P as a load... it adds some noise and ripple
10V 1A
10V 3A
30V 5A
55V 3A
« Last Edit: January 24, 2021, 08:23:36 pm by UniSoft »
The following users thanked this post: BravoV, 4cx10000, ptluis
Offline UniSoft
  • Country: kz
« Reply #565 on: January 24, 2021, 09:11:50 pm »
button LEFT/RIGHT switches the screen layout...
menu design, strings, and even font was copied from my firmware...
screen layouts
menu
The following users thanked this post: BravoV, 4cx10000, Cliff Matthews, ptluis, AaronR
Offline ptluis
  • Country: pt
« Reply #566 on: January 25, 2021, 05:25:41 pm »
Thanks for sharing.  I'm using RD6006 with your custom firmware v1.32.12 without any problems so far. From the tests you have done, do you think it is worth upgrading to the "P" version? What is your opinion about it? I see it still has some ripple at certain conditions. I expected it to be a little more cleaner. Does your custom firmware work on this new version?  thank you.
« Last Edit: January 25, 2021, 05:29:42 pm by ptluis »
Offline UniSoft
  • Country: kz
« Reply #567 on: January 25, 2021, 05:43:04 pm »
...do you think it is worth upgrading to the "P" version?
I don't know...  :-//
For sure - NOT!
With a high probability, I will not make firmware for it. Too much work.
Offline ptluis
  • Country: pt
« Reply #568 on: January 25, 2021, 07:05:36 pm »
For sure - NOT!
[/quote]
I understand. I keep RD6006 and your firmware, it's enough for me. Can you tell me what is your latest stable firmware version for RD6006? Thank you
Offline UniSoft
  • Country: kz
« Reply #569 on: January 25, 2021, 07:47:52 pm »
the latest beta (k)... it is stable enough, at least still no reports about serious bugs.
https://www.eevblog.com/forum/testgear/ruideng-riden-rd6006-dc-power-supply/msg3398072/#msg3398072
Offline ptluis
  • Country: pt
« Reply #570 on: January 25, 2021, 10:32:11 pm »
Thank you my friend. I try this one. for this firmware it is advisable to reset to defaults first and then upgrade firmware right?
Offline UniSoft
  • Country: kz
« Reply #571 on: January 25, 2021, 10:42:04 pm »
no need
The following users thanked this post: ptluis
Offline lnxpro
« Reply #572 on: January 26, 2021, 01:24:26 am »
OK. I hope I didn't fry my RD6012... I accidentally connected a lithium battery to the terminals backwards. (positive to negative, negative to positive.)
Now when I turn on the power supply I get a lower voltage displayed than what it's set to and anything I connect to it won't draw any current. anyone has ever done something that stupid and was the fix expensive? lol.
Offline UniSoft
  • Country: kz
« Reply #573 on: January 26, 2021, 01:57:23 am »
the fuse is blown...
The following users thanked this post: lnxpro
Offline ptluis
  • Country: pt
« Reply #574 on: January 30, 2021, 04:15:16 pm »
Hello Unisoft do you think it's possible to create on RD6006 a "Calibration" menu like the one on the pc software? This way we could make adjustments without the need of a pc. That would be nice!  :-+
