I am looking for a portable bit of test gear that is sensibly priced and has a PWM (Power Wave Modulation) output.
I have a random eBay item that does it but it's an open circuit board and I could do with something that the customer won't start asking questions of. But at the same time I doubt I could get a Fluke Loop calibrator past the boss.
Not Pulse Width Modulation ?
What's the difference if you don't mind ?
You are right, pulse width modulation. Not sure where I got power wave modulation from.
I have to test a machine that uses PWM as part of its tests. It generates and measures so I am looking for a neat way to do this. It 100 Hz at 50% so nothing special. The customer has a Fluke Loop calibrator but that is >£1000 which just for me to use on 4 machines is a little pricey. We are looking to get a handheld multimeter to do the measurement side of it, Fluke 87 or 287 depending on what we can find, that will at least have a use generally around the lab.
