This looks like a new HMC model. Other was the
HMC8012 Digital Multimeter
LinkNew Compact Power Supply
• Realtime voltage, current and power values
• High setting and readback resolution
• Low residual ripple due to linear postregulation
• High energy efficiency, low heat dissipation and quiet fans
• Convenient parallel and serial operation via V/I tracking
• Overvoltage and overpower protection (OVP, OPP) for all outputs
• FuseLink: individual channel combination of electronic fuses
• EasyArb function for user-definable V/I curves
• EasyRamp for simulating a start-up curve
• Sequencing (sequenced start of channels)
• Energy meter (measurement of energy output)
• Data logging to USB flash drive in CSV format
broschure dated 14 May 2014.
