Author Topic: Rigol DP900 / DP2000 Series Hack -  (Read 40282 times)
Offline thm_w
  • Non-expert
Re: Rigol DP900 / DP2000 Series Hack -
« Reply #100 on: August 24, 2024, 12:26:39 am »
Hello everyone,
I just bought a new DP932E with firmware version .22.
However, it’s strange that the MD5 for original SousaMain on my device is d5f765cb69320cdbd710b0aa38dacb29, whereas sensile reports in replay #63 the value as ec69fba52309f6370ed81c55552c4e08.
Does anyone else have a different MD5 for the original SousaMain in FW version .22 compared to the one provided by sensile?
No. You could make a backup copy of that SousaMain, then upgrade to .22, then perform the patch.
Are you sure the full version string was "00.01.01.00.22"?
Offline MarcusN
« Reply #101 on: August 25, 2024, 04:06:18 pm »
Hello everyone,
I used SCPI command *IDN? to determine firmware version.
And it returned value:
Rigol Technologies,DP932E,XXXXXXXXXXXX,00.01.01.00.22
Is there another way to check the firmware version, e.g. using SSH?
Update: After applying upgrade from .22 to .22 ( :)) md5's are correct and patch is working. Thank you thm_w for advice  :-+
« Last Edit: August 26, 2024, 06:05:58 pm by MarcusN »
