Tomki, LoneWolf6912, king2, pmcouto, Performa01 and 11 Guests are viewing this topic.
Santa came early this year!
Edit:dunno way it is upside down
Quote from: Sorama on Yesterday at 06:26:18 pmEdit:dunno way it is upside downThe Magnova has an anti-gravity feature?!
Quote from: pmcouto on Yesterday at 05:42:37 pmSanta came early this year! Did you move to Venezuela?
Hello,Thank you, Blackdog, for your guidance. I followed your instructions closely.I used my Siglent SDG2042X (not hacked), along with a low-noise Keithley 4801 BNC cable, connected to a Tekbox 50-ohm feedthrough termination (DC-1 GHz). Unfortunately, I didn’t have an attenuator available, but I believe this setup was a reasonable alternative.The oscilloscope was set to a 50-ohm termination. I tested a 10 MHz square wave, 1Vpp, with a 50-ohm load on the AWG.Attached is the result from the Magnova. As other members suggested, the limiting factor was indeed the AWG. I apologize for jumping to conclusions too quickly in my previous message.
Quote from: tv84 on Yesterday at 06:18:45 pmQuote from: pmcouto on Yesterday at 05:42:37 pmSanta came early this year! Did you move to Venezuela?Venezuela???Why Venezuela?
