If look at 120824 picture , take look of block of pcb tracks on upper righthand section , going down to bottom sees little pcb tracks ,,
Since slide contacts are x2 in other pictures each , it seems the very lower ones are 3?
But anyway , 2 pcb tracks each for contact , starting from top 2 , then 2 then 2 etcetera , then position switch above pcb and check and look from the side to follow suit , only trouble is lower 3?(maybe) .
