Just received unit. Initial impression is UI is no faster than the RTB2004.
Spectrum mode disables waveform display for much faster update,and frequency range also appears much wider. Not had time to explore more details yet.
Digital probe plug+cable only sticks out 20mm to the right relative to front of frame, so not a huge deal. Cables are reasonably flexible - similar to 2004 ribbon.
