Author Topic: R&S RTM3004 The Swiss-Knife-Oscilloscope  (Read 50016 times)
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: R&S RTM3004 The Swiss-Knife-Oscilloscope
« Reply #75 on: January 27, 2018, 12:15:28 am »
My biggest complaint about the R&S scopes is the slightly sluggish UI, when compared the Keysight. I was a bit disappointed the 3004 didn't improve on this.
Compared to others it's probably fine, I've just been so used to Agilent then KS over the years.
I think there is scope to improve this by avoiding some of the transitions etc. when menus appear and disappear, but it does seem to miss button-presses sometimes.
I'll probably use the 3004 as my day-to-day scope for a while to see how it feels in everyday use.
Oh, and those damn clicky encoders...
Day Job: Mostly LEDs
Online nctnico
« Reply #76 on: January 27, 2018, 01:12:01 am »
Problem is, despite the shortcomings (memory, noise, can't apply decodes after an acquisition) keysight has a scope with all the options others have only in higher class scopes.
What kind of options?
Offline JPortici
« Reply #77 on: January 27, 2018, 10:24:47 am »
The whole set of decoders!
I hope that the fact that they released this scope with more than the usual five (SPI,I2C,UART,CAN,LIN) is a sign that they will add more in the future, but who know what will really happen?
to me this is more important than having a gazillion sample memory depth
« Last Edit: January 27, 2018, 10:26:28 am by JPortici »
« Reply #78 on: January 27, 2018, 11:09:11 am »
What other decoders would you want? USB and Ethernet are the only ones that come to mind.
bear in mind you can pull waveform data off quickly and easily via USB, so offline analysis should be doable.
Of course what would be really nice is an architecture where you could write your own.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #79 on: January 27, 2018, 11:58:22 am »
I'm looking at it here: https://www.batronix.com/shop/oscilloscopes/Rohde-Schwarz-RTM3004.html
RTM3004 -> 4510€ (minimum with 4 channels)
RTM-PK1 Option Bundle -> 2975€ (triggers, decoders, etc)
TOTAL: 7485€
Is that right? Or is there any launch campaign or bundle or something somewhere?
« Last Edit: January 27, 2018, 12:02:57 pm by GeorgeOfTheJungle »
Online nctnico
« Reply #80 on: January 27, 2018, 12:01:16 pm »
The Keysight 3000T seems to support these decoders according to the datasheet:
I2C
SPI (2/3/4 wire)
RS232/422/485/UART
CAN / CAN-dbc /CAN-FD (CAN-FD ISO)
LIN / LIN symbolic
SENT
CXPI
FlexRay
MIL-STD 1553
ARINC 429
USB PD
I2S
User-definable Manchester / NRZ
That is quite an impressive list. Ofcourse it depends on what you are working on whether you would need these decoders or not. To me user definable Manchester / NRZ would be handy every now and then.
« Reply #81 on: January 27, 2018, 12:09:47 pm »
TOTAL: 7485€
For 350MHz and up there is a bundle with a free spectrum analyzer :
https://www.testforce.com/news/promos/free-spectrum-analyzer.html
The following users thanked this post: GeorgeOfTheJungle
« Reply #82 on: January 27, 2018, 12:11:08 pm »
BTW I was surprised that there is still no ability to trigger internally from the wavegen/wavegen sweep
  • Country: tr
« Reply #83 on: January 27, 2018, 12:17:49 pm »
USB PD
That's USB 1.0 (USB low-speed (1.5 Mbit/s) and full-speed (12 Mbit/s)), yes? How much does a 3000T with all these triggers/decoders cost? What kills me is the 4M max mem depth, that's less than the (older) infiniivision I have now.
Offline hwj-d
  • save the children - chase the cabal
« Reply #84 on: January 27, 2018, 01:05:21 pm »
Is trigout-aux stable/reliable now?
Offline 3db
« Reply #85 on: January 27, 2018, 09:55:41 pm »
Nice review Mike.
Thanks for the effort.
3db.
« Reply #86 on: January 27, 2018, 09:57:11 pm »
It still seems rather erratic , with variable-sized gaps in the bursts, and the time between triggers being rather longer than expected - not looked in detail yet.
The following users thanked this post: hwj-d
Online nctnico
« Reply #87 on: January 27, 2018, 10:50:55 pm »
AFAIK it is not uncommon for DSOs to have a variable trigger rate. At some point the data will need to be processed and depending on mode/settings/math the interruptions will be longer or shorter.
Offline TheSteve
  • Living the Dream
« Reply #88 on: January 27, 2018, 11:17:24 pm »
Thanks for the tear down Mike - the scope looks to be very nicely built. The front end amplifiers needing such a heatsink surprised me though. The equivalent part on the Keysight 2000/3000 scopes has nothing.
Could this be a product of them trying to go for lower noise because of the 10 bit ADC?
VE7FM
« Reply #89 on: January 27, 2018, 11:24:12 pm »
Hard to say.
May also be for stability, keeping temps as low as possible. With 500uV/div, DC drift is probably a significant issue.
I measured the temp on the big FPGA sink and it was only about 40 deg.C so the HS was overkill but keeps temps down and means they can use a quiet fan.
Offline hwj-d
« Reply #90 on: January 28, 2018, 01:28:07 am »
Thanks Mike for your nice competent work.  :-+
Thanks ntcniko for your answer.
Maybe I just expect too much from such a modern scope. Perhaps in practice, it is more likely to be able to receive any trigger event for, for example, synchronization purposes, than precisely each one. So, it is more like a slide rule, than a precise counting calculator (edit: the trig-aux out, not the scope), right? If it's so, than that's an interesting insight for me.  :-/O
« Last Edit: January 28, 2018, 01:41:19 am by hwj-d »
« Reply #91 on: January 28, 2018, 01:46:25 am »
I assume that the trig-out really does output a pulse exactly on every trigger event, but it would be interesting to check that this is actually the case. I have some ideas of how to test this definitively.
Something that definitely does happen is that on each trigger it captures data both to the left and right of the displayed screen, so the shortest trigger-to-trigger time is always significantly more than one screenful. There may be situations like catching occasional glitches where it would be useful to change this behaviour to only do one screen-time's worth of data before re-arming.
Offline Someone
    • send complaints here
« Reply #92 on: January 28, 2018, 02:10:16 am »
The confusion arrives because the trigger output on most scopes is a replication of the acquisition trigger, which is why the trigger rate jumps up when switching to a (ideally circular) segmented acquisition mode as its not (generally) processing the acquisitions and has shorter dead time.
Offline hwj-d
« Reply #93 on: January 28, 2018, 02:37:35 am »
Ok, got it. Thanks again.
Yes, that's also reasonable. Thanks too.
Offline maginnovision
« Reply #94 on: January 28, 2018, 09:48:47 am »
I tested my RTB2004 and the trig out appears to be acquisition-based, but if you use the counter and set it to trigger it is actual triggers. I assume the 3K will be the same? I just checked with a 24MHZ clock. Used 1252B freq counter to read trig out from AUX out port, and verified by changing memory depth. Bigger depth, lower AUX trig out frequency but more stable Trigger Counter output, lower depth the opposite.
« Last Edit: January 28, 2018, 09:51:00 am by maginnovision »
Offline ws2812b
  • Country: at
« Reply #95 on: January 28, 2018, 07:05:04 pm »
I summarised the differences from the datasheets earlier in this thread, and have subsequently edited for the things that were wrong in the datasheets.
First vid should be done sometime over the weekend.
thanks for the vid. Things like pulling out the menu was exactly what I meant,
@Rich: do we get this for the RTB2k as well?
Offline MikeP
  • Country: ua
« Reply #96 on: January 29, 2018, 01:01:26 pm »
 Rich.
 I see improved noise performance. Are the distortions of the input path reduced in comparison with the RTB?
 Mike, great video. Thank you.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #97 on: January 29, 2018, 03:54:08 pm »
Could also be they are using a different process technology with a bit more noise and need more current to offset it? Since power isn't critical in this application it could be easier for them to just up the current (and thus power) instead of having to jump through hoops to get the noise down without increasing power.
Also seems like the noise performance is better than the competition (it has to be to get the most out of that 10 bit ADC on the low ranges).
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Rich@RohdeScopesUSA
« Reply #98 on: January 29, 2018, 04:39:23 pm »
Yes, it is planned in a future release.
-Rich
The following users thanked this post: ws2812b
« Reply #99 on: January 29, 2018, 04:41:58 pm »
Rich.
The 3000/4000 use a new front-end that is different from the 2000's.  While the 2000 has excellent noise for the its class, the 3000/4000 are even better while still offering full bandwidth (up to 1GHz) at all volt/div settings, even 500uV/div.
-Rich
The following users thanked this post: MikeP
