ElectroMan,
Please explain how you did the NAND dump and why the first 0x0800 0000 seem all good and the rest seems to contain raw NAND bytes plus OOB.
Whatever "filesystem" they are using seems to place 16 bytes of NAND management data at the beginning of each block after block 0 (possibly data for previous block?) I did not look too much at that and just discarded it, as it was corrupting the extracted firmware sections.
Do you have other specific questions about the process? I explained the methodology in the first post and provided the script I used here:
https://www.eevblog.com/forum/testgear/rs-rtb2004-snooping/msg3242084/#msg3242084I was basically emulating a crude NAND controller driver via memory reads/writes through OpenOCD to get the NAND contents.
The image that was extracted seems to have all the software (and a bunch of different versions), but if there are errors in the latter memory regions it would be difficult to tell for certain what should be there. I double-checked my binary math a few times, and as all the important data seemed to be there I assumed some of the garbage later in the file was an artifact of however they were flashing these from the factory.
Note that the apps seem to use about 25-30M of a 512M flash. A lot of the other stuff there are older firmware versions (the scope came with a version newer than most of them on the flash). This leads me to believe the image they use to flash these devices has a lot of stuff left over from earlier testing stages.
It is, of course, also possible there's something wrong with my methodology and my binary math fell apart. A second set of eyes on that would be welcome.
