Hi all, and new to the forum shout out to Dave!!
I’ve just found here the Tekronix DMM 4020 and Fluke 8808a are one in the same.
I’ve already (by mistake) purchased Agilent 34401a. It’s a quiet good instrument but doesn’t do exactly what I want. I was looking for dB to watt function.
David @ ElPaso Tube Amps uses his Tek math function to select 2,4,8 ohm across the dummy load for output in watts.
I suppose my question is am I limited to these two models for what I’m trying to accomplish?
Trying to avoid another $300+ mistake.
Thanks in advance
Jim
