Hi all,
I own the HP 8595E which comes with 023 option (RS232). What I'm trying to, with no success yet, is to connect the HP with my PC to control it remotely.
I'm using a USB to RS232 adapter which is functional, confirmed by jumping RX/TX signals but i can't receive any replies from the SA while i can probe the commands I send on the SA DB-25 connector. The wiring on DB-25 connector is custom made. The RS232 configuration (baud rate etc) has been cross checked and is similar on both SA and RealTerm.
The commands i have tried with no results are
ID;
IP;
*IDN?
The strange thing now comes on DB-25 connector pinout. The HP 8590 Series Spectrum Analyzer Programmer's Guide
https://www.keysight.com/us/en/assets/9018-01030/user-manuals/9018-01030.pdf gives the following pin out. Page 720 where the option it refers to is 043 which is different from 023 I have but both are RS232. I don't know if that makes any changes to the connector pinout but I couldn't find any relative info regarding option 023.
1. DCD Measured 0V
2. RxD Measured -11V
3. TxD Measured 0V
4. DTR Measured +11V
5. GND Measured 0V
6. DSR Measured 0V
7. RTS Measured 0V
8. CTS Measured 0V
9. RI Measured 0V
While the universal DB-25 pinout is
1. Shield Ground
2. TxD
3. RxD
4. RTS
5. CTS
6. DSR
7. GND
8. DCD
20. DTR
From the above measurements (reference the connector chassis) I may assume that the SA TxD is Pin 2 and RxD Pin 3 while the GND pin is still not clear which one is. Is it pin 5 or pin 7?
There is also a note "The spectrum analyzer checks its CTS input before transmitting data to the computer. If the CTS line is false, the spectrum analyzer will not transmit data. The spectrum analyzer transmits data when the CTS line is true"
So I tried
1. Connecting my PC USB-RS232 adapter TxD to pin 3 of SA DB-25, RxD to pin 2 and ground on pin 5. No results
2. Connecting my PC USB-RS232 adapter RxD to pin 3 of SA DB-25, TxD to pin 2 and ground on pin 5. No results
3. Connecting my PC USB-RS232 adapter TxD to pin 3 of SA DB-25, RxD to pin 2 and ground on pin 7. No results
4. Connecting my PC USB-RS232 adapter TxD to pin 3 of SA DB-25, RxD to pin 2 and ground on pin 7 and set CTS pin 8 to -6V using an external power supply in order to set it True. No results
5. I also tried connecting 8 CTS, 7 RTS and 1 DCD together but nothing changed in the communication.
6. I also tried different combinations of the above that i didn't note down.
Does anybody have the confirmed pinout of the DB-25 RS232 connector of SA 8595E?
