Supply voltage should not be a problem. The scope supplies 4V on VCCI and -2.4V on VEE so total supply voltage is 6.4V for VCCI. Even for VCCO it is 2.4V to ground + 2.4V to VEE so 4.8V in total which should be close enough
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It would be also possible to use some other, cheaper RSPECL comparators (are there any? Maxim has something) to build lower performance logic probe. These RPL1116 logis probes are a bit over engineered in my opinion. LMH7322 are specified up to 4GHz so quite an overkill for 100MHz probe.
According to datasheet, sampling rate of digital channels on MSO5000 is 1Gsps. 700ps propagation delay on LMH7322 ensures that the sampling time lags no more than 1 clock behind actual data. But this is only for the comparator itself. What about input attenuator and propagation through connector cable and scope's internal circuitry?
MSO5000 datasheet says:
Min. Detectable Pulse Width: 5 ns
Maximum Input Frequency: 200 MHz
Inter-channel Time Delay: 2 ns (typical), 5 ns (maximum)
Am I right that any LVDS comparator should work with RSPECL inputs at this voltage levels (2.4V)?
From LMH7322 datasheet: "When used in combination with a VCCO supply voltage of 2.5V the outputs have LVDS compatible levels."
