you can use a Rubidium clock for the reference, 10MHz output, only 200 USD with box, btw, I have a SMU200A signal generator, the clock tolerance exceed 0.05ppm, I asked R&S, no way by command to calibrate it, is that true? for Agilent E4438C, it is easy to re-cal the clock.
