Just wondering about a few use cases on the RBT2004?
(Modification: After I wrote this I discovered the RTM documentation for "R&S RTM-K1" and R&S - K15. I read another sheet that implying that the functionally of these options are the same for the RTB, Is that the case? If so my question is answered:) )
USE Case 1 - Long term serial decodingWith the memory upgrade of the RTB2004. If I set the scope to 10Ks per record, the manual says I can have 13107 records.
If I am; a) using a serial trigger (Say a given address, or some pattern) and b) assume I can fit a query response in one record based upon an assumption of approx. 2000 digital bits per record, yielding about 200 bytes of data.
1) Are the above assumptions reasonable?
2) Is each record stored uniquely (tagged), in 10Ks chunks? Is the serial decode information retained, or is it recalculated each time.
3) Assuming this is acting like segmented memory. How much time can elapse between triggered events? Basically, I want to know how long can I wait for bad stuff to happen? I my case, want to set up and then wander over to the remote sensors etc and, stuff them in crushed dry ice, wiggle wiggle (reference for our aussie friend) them like crazy and generally try to simulate nasty conditions that would cause the noise and communication failures. It sounds as if with 13k records I could go a very long elapsed time (well beyond my expectation, but there again ... expect the unexpected)
I answered this by reading
https://cdn.rohde-schwarz.com/pws/dl_downloads/dl_common_library/dl_brochures_and_datasheets/pdf_1/RTB-K15_RTM-K15_Fast_ac_en_3607-1220-92_v0200.pdf4) In the manual I see no mention of tabular representation of the decode. Is that available?
5) I assumed from my reading that I can save the 160 Ms history to a file for storage. If so could tests like the one above be saved for future analysis? I am particularly concerned about how decodes are replicated.
Use case 2 The function generator bit pattern capability.Can the scope be setup and as a Master in an SPI Master/Slave configuration to generate queries?
If so what are the limitations?
I will continue to read through the remote control commands some more but I have a sense that the art of the possible might be very significant here.
Thanks in advance
PS Wife and daughter think I am absolutely crazy reading oscilloscope manuals...
