I bought this Source Meter mainly for its modulation capability. This is the first time I am quite disappointed by a Rohde & Schwarz instrument. The graphical view function only has a single time base 5 s/div in which the current is heavily low pass filtered. Thus, you cannot display any of the high speed logging. Rather, you need to save a .cvs file on a USB stick. Then, you can display it in Excel. My only hope is that the graphical view function will be improved. For a $5k instrument that is not what I expect. There is a Logging & Charting Tool you can download but it does not work. I installed it and every time I search for the instrument, I get "No NGx devices found". This rather clumsy tool needs the VISA library and some drivers which I installed but no success. The second tool available is a Sweep tool which has pretty much the same interface and that one works. I can successfully connect to the instrument. So, I am pretty sure the Logging & Charting Tool has some bug.
Anybody have the same experience?
atx
