Author Topic: Anyone cracked open that "isolation" probe before?  (Read 1312 times)
Offline MecanixTopic starter
  • Country: cc
« on: November 22, 2021, 02:12:50 am »
Looking to acquire isolation to safely measure AC switching with a scope for a SMPS design I'm experimenting with and came upon this product advertised as "Isolation Probe".
Are those actually optically isolated or mislabeled for a differential probe?
« Last Edit: November 22, 2021, 03:18:16 am by Mecanix »
Offline PartialDischarge
Re: Anyone cracked open that "isolation" probe before?
« Reply #1 on: November 22, 2021, 02:24:38 am »
That is a diff probe
The following users thanked this post: Mecanix
  • Country: cc
« Reply #2 on: November 22, 2021, 02:30:20 am »
Right. Glad I've asked, thanks MasterTech.
I take that there is nothing remotely isolated in that tool?
« Reply #3 on: November 22, 2021, 02:34:59 am »
It provides isolation between the DUT and the oscilloscope.
  • Country: cc
« Reply #4 on: November 22, 2021, 02:57:11 am »
Presuming few 1kv rated current limiting resistors and a comparator (or more)? Sounds smokey!
I'll dig into this later on today, not familiar with those highVAC toys (thanks guys).
Got a feeling I just need an inexpensive 220V-to-220V transformer, have it canned in a small metal box and call it a day...
« Reply #5 on: November 22, 2021, 04:49:46 am »
It’s very unlikely a mains transformer designed for 50/60Hz operation will give suitable frequency response for SMPS operating in the 15-50KHz region.
Offline BrokenYugo
« Reply #6 on: November 22, 2021, 07:09:40 pm »
Dave has torn down a couple and yes that's more or less what goes into any "high voltage" differential probe, big divider (usually 4 megs each side for whatever reason) with an amplifier in the middle. I think the money is mostly in the compensation and fine tuning to give the whole thing a flat frequency response.
https://youtu.be/GOlgaEK2Hsk
  • Country: cc
« Reply #7 on: November 23, 2021, 03:10:40 am »
Interesting tool. Dave's vid confirmed what I've seen from another model spy shots I was looking at yesterday... just couldn't figure out the 'isolation' part. But after watching the vid and finally understanding all starts to make sense now. Regardless, spoke to a supplier (not the one of the pic, another one) and was told I needed both; the isolation transformer + diff probe kit (if done the correct/safe way is required, apparently). So I'll just gear up and cancel Friday's evening cinema and popcorn I guess.
Thanks guys, all good pointers I appreciate that. Man all that tooling... adds up quick just for a custom transformer and fet switching analysis. Hope I'll have the chance the re-use all of that stuff throughout the years...
« Last Edit: November 23, 2021, 03:13:02 am by Mecanix »
