Author Topic: Rohde & Schwarz HMO1202 - Come-a-Gutsa  (Read 2656 times)
Offline EEVblogTopic starter
« on: November 20, 2021, 04:31:06 am »
The following users thanked this post: dynorat
Offline trophosphere
Re: Rohde & Schwarz HMO1202 - Come-a-Gutsa
« Reply #1 on: November 20, 2021, 04:45:20 am »
As a temporary/semi-permanent one off measure, one could use aluminum foil to see if noise improves. Just make sure it makes a good connection to ground.
« Reply #2 on: November 20, 2021, 06:48:24 am »
Someone needs all their screwdrivers confiscated.  :P
The following users thanked this post: TheDefpom, Gary350z
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: November 20, 2021, 08:12:09 am »
The first rule of forgot the shield club is....... :-X
« Reply #4 on: November 20, 2021, 08:27:28 am »
Actually, Muttley needs a new DSO....how much would you offer Muttley ?
C'mon now be kind and make it at least $50.  :-DD
Got a spare alloy pie dish to knock up a shield with ?
Offline DEV001
« Reply #5 on: November 20, 2021, 11:39:28 am »
Digikey has a decent selection of various shields that you may be able to adapt for use in your scope for only a couple of dollars.
https://www.digikey.com/en/products/filter/rf-shields/867
The following users thanked this post: EEVblog
Offline Old Fart Analog Engineer
« Reply #6 on: November 20, 2021, 04:51:28 pm »
Of course the obvious answer is to order one from R&S!  ROFL 🤣🤣🤣.
These are made of cold rolled, tinplated steel.  Practical idea: Get one from one of your "dumpster dives" and reform it with pliers and tin snips.  The exact dimensions don't matter, just so it does not short out anything.   Since you want to be a perfectionist, yes there are companies that would make you one, but at high costs, the main one being an expectation of a production quantity  order follow-on.
Offline 2N3055
  • Country: hr
« Reply #7 on: November 20, 2021, 07:35:41 pm »
Noise is 50 Hz.
Other can has additional magnetic shield layer stuck on it...
Something that looks like sintered ferrite sheet...
Offline Doctorandus_P
« Reply #8 on: November 21, 2021, 03:26:05 pm »
Why is the USB connector upside down?
Rigol also does that. It took me the better part of an hour to turn that connector around in my DS1052E.
Offline AJ3G
« Reply #9 on: November 22, 2021, 02:17:43 am »
Dave:
I just placed an order through my company from this outfit:
https://www.orbel.com/emi-rfi-shielding/board-level-shielding
We used them to fabricate some custom shields for bandpass filter assembly, to include cutouts for tuning the VARICAPS. I think in orders of 50 we are getting these shields for about $3.00/per. They did all the prototyping for us, but you may find a suitable stock item in their inventory.
Rich
« Reply #10 on: November 22, 2021, 03:29:29 am »
Fixed:
The following users thanked this post: egonotto, thm_w
Online David Hess
  • DavidH
« Reply #11 on: November 22, 2021, 06:15:13 am »
It would take less than 10 minutes to notch and bend a piece of brass sheet from a hobby shop.  They might also have tin plated steel sheet.
Offline Fungus
« Reply #12 on: November 22, 2021, 09:16:02 am »
It takes much more than ten minutes to go to the hobby shop and buy it though...  ::)
Online David Hess
  • DavidH
« Reply #13 on: November 22, 2021, 04:09:01 pm »
Picky, picky ... If I did not have brass sheet, then I have a holiday cookie tin here that I could cut up.  I would use the cookie tin just to have Frosty, Santa, and Rudolf inside my oscilloscope guarding measurements from noise.
The following users thanked this post: nctnico, egonotto, thm_w, 2N3055
Offline Fungus
« Reply #14 on: November 22, 2021, 04:15:04 pm »
We're only in November and you already ate all the Xmas cookies?
Lock Picking Lawyer would use a Red Bull can but I know Dave doesn't drink anything like that.
Luckily Dave has a magic dumpster that can produce absolutely anything on demand.  >:D
Those little R&S 'scopes look awesome. It's a pity they never made them at a reasonable price.
« Last Edit: November 22, 2021, 04:21:35 pm by Fungus »
Online David Hess
  • DavidH
« Reply #15 on: November 23, 2021, 05:27:39 am »
It is a cookie tin from Christmas past.  I do not know what is in it ... eww, fossilized cookies of Christmas past.
R&S make the DSOs I would be most interested in if I bought a new one, but I would want to do an evaluation.  Some of their DSOs can operate with multiple acquisition modes simultaneously during decimation.
« Last Edit: November 23, 2021, 05:30:53 am by David Hess »
