Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 358550 times)
Online Fungus
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #2025 on: June 16, 2024, 05:20:02 pm »
If you download the Analog Discovery software you can use it for free on your PC sound card.
I haven't tried it but I'm fairly sure it will do Bode plots up to whatever frequency your sound card supports.
(eg. 192kHz sample rate)
Online Fungus
« Reply #2026 on: June 18, 2024, 04:25:53 am »
I had both DHO800 and SDS800X HD
While we're here, how do the supplied probes compare?
Offline norbert.kiszka
« Reply #2027 on: August 01, 2024, 04:05:01 pm »
I have had a Lite-On PSU, as it was shipped with DHO924S. Not very best PSU, but for some reasons I decided to do Riso (insulation tester) measurements between PE and output ground. Normal ohm meter showed 1 MΩ. 500 V test gave same result. 1 kV ended with fail - 1 MΩ become 30 kΩ.
If something is powered from grid, at least in Europe, I expect this to handle 2 kV surge without any problem. Anyway, there are some photos from teardown and small reverse engineering of PE-GND path.
Both capacitors are 100 nF, but second one became more like a resistor with value depending on a moon phase.
The following users thanked this post: AndyBig, zelectronicauy
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #2028 on: August 19, 2024, 08:43:37 am »
Hi, guys!
Could you read my topic & reply to my question about 802/812?
« Last Edit: August 19, 2024, 01:33:29 pm by Yuriy V. »
Online Fungus
« Reply #2029 on: August 19, 2024, 03:26:16 pm »
Hi, guys!
Very few people but 2 channel models. It's possible nobody here has one.
Offline carl0s
« Reply #2030 on: August 21, 2024, 10:02:26 pm »
Less than £299 including delivery and VAT from Banggood right now (DHO804).
I wanted a portable scope.. really wanted to buy another Siglent but no HDMI and no powerbank option. So a DHO804 it is!
Carl
The following users thanked this post: Fungus
Offline TimFox
« Reply #2031 on: August 21, 2024, 10:31:17 pm »
Hi, guys!
It’s impossible that nobody here owns a two-channel DSO.
The following users thanked this post: Yuriy V.
Offline Elextro
« Reply #2032 on: August 22, 2024, 10:30:46 am »
Hello, I have already answered you in the thread you asked about. My conclusion is that activating the trigger does not influence the maximum sampling frequency, only activating the two channels divides that factor in half. Greetings
Online Fungus
« Reply #2033 on: August 22, 2024, 01:19:38 pm »
This is very likely, but I'm not going to garantee it because I don't own one.
« Reply #2034 on: August 23, 2024, 01:08:31 am »
Every scope can be modified (another PSU) or powered from a battery->AC inverter.
Online Fungus
« Reply #2035 on: August 23, 2024, 02:44:20 am »
Yeah, but the Rigol works off a pocket-sized phone charger.
« Reply #2036 on: August 23, 2024, 11:20:18 pm »
You think that other scopes can't be modified to do the same thing?
Online Fungus
« Reply #2037 on: August 24, 2024, 04:55:58 am »
Sure, but you don't have to modify the Rigol.
« Reply #2038 on: August 24, 2024, 05:25:36 am »
Unless you require a Line trigger.
Online ebastler
« Reply #2039 on: August 24, 2024, 10:28:37 am »
Umm -- if you have line voltage around to trigger on, you might as well use it to power the scope?
Offline metrologist
« Reply #2040 on: August 26, 2024, 02:53:45 pm »
Wait, so this Rigol does not support line trigger? Because I can't remember ever using it.
Offline egonotto
« Reply #2041 on: August 27, 2024, 05:23:29 am »
Hello,
many scopes with line triggers can measure the mains frequency. This is sometimes quite interesting in increasingly unstable networks.
Best regards
egonotto
« Reply #2042 on: August 27, 2024, 06:29:10 am »
Hello,
Best regards
egonotto
Yes, when they have a mains supply into the scope to couple line frequency from.
You can't get that from an external wallwart power supply.
Offline khomouda
  • Country: eg
« Reply #2043 on: September 04, 2024, 01:50:09 pm »
Hello friends, I know it is strange question, did anybody open the 2 channel scope, and is there a way to add another 2 channels (BNC) if the firmware is upgraded to 900 series and 4 colors of the buttons are lighting, I bought the 2 channel by mistake and don't want to buy another honestly
thanks
Offline AndyBig
  • Country: ru
« Reply #2044 on: September 04, 2024, 09:09:03 pm »
thanks
There is no frontend for the fourth channel, but 3 channels can be made.
The following users thanked this post: khomouda
Offline Pao3
  • Country: jp
    • Let's try that! (Sore, Yatte Me-Yoh!)
« Reply #2045 on: September 13, 2024, 12:04:16 pm »
This is my first post.
I was thinking of buying the Rigol DHO804, so I was looking at various posts here.
I saw a post on Rigol Japan's X on September 6th that said,
"RIGOL plans to release new oscilloscopes and signal generators between October and November.
If you fill out the following survey, you will be the first to receive product information."
(https://x.com/RigolJapan/status/1831947042299732079)
Is this post fake?
Or is Rigol releasing a new oscilloscope?
If so, I think I'll wait until October to buy it.
(I'm using Google Translate.)
Online Fungus
« Reply #2046 on: September 13, 2024, 02:27:21 pm »
They are... but it will be a very expensive one.
The following users thanked this post: Pao3
« Reply #2047 on: September 13, 2024, 09:13:01 pm »
For me, lack of source code of used software under GPL licence is a big pain in the ... scope. I sent them many e-mails and only thing I received, was a SMTP confirmation of received message (most likely sent by human, not by software). If they will not send me this code, my next shopping and recommendations will be far away from a Rigol.
Online Fungus
« Reply #2048 on: September 13, 2024, 09:52:42 pm »
Good luck buying an oscilloscope if that's a deal breaker.
« Reply #2049 on: September 13, 2024, 10:28:17 pm »
Are You suggesting that other scopes doesn't have something that Rigol can do?
