Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 350588 times)
Offline bulba99
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #1725 on: November 17, 2023, 02:53:02 pm »
The new firmware has been withdrawn from the Chinese website.  :palm:
Offline Serg65536
  • Country: ua
« Reply #1726 on: November 17, 2023, 03:19:58 pm »
The direct link works.  :popcorn:
Offline bulba99
« Reply #1727 on: November 17, 2023, 03:22:46 pm »
Maybe, but there has to be some reason for the withdrawal.
Online Fungus
« Reply #1728 on: November 17, 2023, 05:10:24 pm »
The link was to a file was on Aliexpress so maybe Rigol had it removed.
« Last Edit: November 17, 2023, 05:17:45 pm by Fungus »
The following users thanked this post: RAPo
Online Fungus
« Reply #1729 on: November 17, 2023, 09:45:27 pm »
How many people have seen this screen on their DHO?  :popcorn:
Offline Martin72
  • Testfield Technician
« Reply #1730 on: November 17, 2023, 09:48:26 pm »
You broke it !  :scared:
(Kierkegaard)
Online Fungus
« Reply #1731 on: November 17, 2023, 09:59:36 pm »
I've got WiFi!  :)
The info screen says "disconnected" but WiFi is working and the IP address is correct.
« Last Edit: November 17, 2023, 10:03:01 pm by Fungus »
The following users thanked this post: Serg65536
Online Fungus
« Reply #1732 on: November 17, 2023, 10:12:18 pm »
This is my TP-Link WiFi adapter:
I'm very surprised it works - I couldn't find a slot to insert the CD in the Rigol!
« Last Edit: November 17, 2023, 10:50:36 pm by Fungus »
Offline bulba99
« Reply #1733 on: November 18, 2023, 12:13:43 pm »
WiFi settings are also remembered after the oscilloscope is restarted.
Offline Serg65536
  • Country: ua
« Reply #1734 on: November 18, 2023, 01:45:48 pm »
What is the app full name?
Offline bulba99
Online Fungus
« Reply #1736 on: November 18, 2023, 01:59:19 pm »
Yes.
Online Fungus
« Reply #1737 on: November 18, 2023, 02:01:13 pm »
It's the Android OS App settings.
Offline bulba99
« Reply #1738 on: November 18, 2023, 02:01:45 pm »
Yes.
It wasn't a question.  :-DD
Online Fungus
« Reply #1739 on: November 18, 2023, 02:22:53 pm »
It wasn't an answer.
Offline RosePeach
« Reply #1740 on: November 19, 2023, 05:09:44 pm »
Hello all, I just placed an order for the DHO802. Is there a list of hacks I should do when I get it? Or is there a list of things to know when it arrives?
Offline UK
  • Country: ma
« Reply #1741 on: November 19, 2023, 05:14:11 pm »
... Is there a list of hacks I should do when I get it? Or is there a list of things to know when it arrives?
Check this thread
« Last Edit: November 19, 2023, 05:15:42 pm by UK »
Offline Serg65536
  • Country: ua
« Reply #1742 on: November 19, 2023, 07:25:35 pm »
Please, report us if there is some things specific for the 2ch version.
Offline idolclub
« Reply #1743 on: November 22, 2023, 03:48:58 am »
Rigol releases new firmware v00.01.02.00.00 for DHO800 / DHO900 ~ 2023.11.16
[Model Supported] All the DHO800/900 series oscilloscopes
[Latest Revision Date] 2023/11/2
[Updated Contents]
v00.01.02.00.00  2023/11/2
1. Self calibration optimization update
2. Solve the problem of UltraLab startup connection failure
3. Solve the problem of failure to save waveform in wfm format
4. Add education model equivalent settings
5. Solve the problem of unresponsive touch on startup screen
v00.01.01.00.02  2023/09/12
2. Update Help Documents
Download:
https://download.rigol.com/cn/Firmware/Digital%20Oscilloscope/DHO800%26DHO900/DHO800_DHO900(Software)Updatev00.01.02.00.00.zip
The following users thanked this post: Mechatrommer
Offline bulba99
« Reply #1744 on: November 22, 2023, 05:58:26 pm »
This is the same file that was previously published.
Without any changes.  :-//
Offline Martin72
« Reply #1745 on: November 22, 2023, 08:29:38 pm »
I would not use any firmware that is not also available from rigol.na and/or rigol.eu .
(Kierkegaard)
Offline Bad_Driver
« Reply #1746 on: November 26, 2023, 08:15:33 pm »
The following users thanked this post: zrq
Offline enson72
  • Country: ua
« Reply #1747 on: November 27, 2023, 12:43:57 pm »
Tell me, why does adb not see my DHO ? USB debugging enabled. What else needs to be done?
Online Fungus
« Reply #1748 on: November 27, 2023, 03:13:42 pm »
You also need to tell us what you typed in ADB (not just "it failed!")
Offline enson72
  • Country: ua
« Reply #1749 on: November 27, 2023, 04:04:49 pm »
The screenshot shows. Typed device search "./adb devices" typed in the terminal.
