Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 358754 times)
Offline mwb1100
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #1700 on: November 10, 2023, 06:31:06 pm »
Can anybody recommend a known model of WiFi dongle that works with these?
@scopestuff confirmed that the TP-Link TL-WN725N works.  That's the WiFi dongle supported by the SDS1104X-E (so some people here will already have one).  In the US it's available on Amazon for $10.
Also be careful with TP-Link TL-WN725N which someone advised as compatible, since it has 3 versions... V1 uses RTL8188CUS, and V2/V3 use RTL8188EUS
The one I got from Amazon exactly 1 year ago was hardware Rev 3.8 (from a label on the box).  I'd think that anyone purchasing new stock should be fine.  It enumerates as:
0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
(I really hate that WiFi vendors often don't change model numbers when they change to an incompatible chipset)
« Last Edit: November 10, 2023, 06:40:53 pm by mwb1100 »
Offline Sys_Bug82
« Reply #1701 on: November 10, 2023, 07:05:31 pm »
Thanks, i didn't know that there are so many versions of RTL8188 dongles. And many offers don't specify which version it is.  I ordered a new one which should be the EU version.
Offline sergk
« Reply #1702 on: November 13, 2023, 03:38:09 pm »
I'd appreciate it if someone who already has DHO900 with LA and caliper could make four precise measurements. #3 and #4 are the distances between the front surface of the scope shell and the plastic edge of the IDC socket, both sides should be measured... it seems to me the right side is slightly higher than the left.
I'm trying to adapt/design a nice-looking shell of DIY LA for new DHO scopes.
Here is my measurements:
1 - 10.5mm
2 - 74mm
3 - 6.6mm
4 - 8mm
Yes, right side is higher (photo attached), and as you can see - edges are rounded, so 1 and 2 is slot size without edges, also socket is slightly smaller, than LA slot in plastic (second photo).
The following users thanked this post: Mechatrommer, UK
Offline Sys_Bug82
« Reply #1703 on: November 14, 2023, 06:49:55 pm »
My new Wifi dongle today and I got it working with my DHO804.
I connected the Wifi dongle and a USB Keyboard over a powered USB hub to the oscilloscope, then i turned the oscilloscope on.
With the following adb command i opened the android settings app:
adb shell am start com.android.settings
Then i could choose the wifi network and enter the password with the usb keyboard.
to exit the settings app i used:
adb shell am force-stop com.android.settings
Is there an a way to get an onscreen keyboard?
The following users thanked this post: bulba99, Serg65536
Offline idolclub
« Reply #1704 on: November 16, 2023, 04:32:26 pm »
Rigol releases new firmware v00.01.02.00.00 for DHO800 / DHO900 ~ 2023.11.16
[Model Supported] All the DHO800/900 series oscilloscopes
[Latest Revision Date] 2023/11/2
[Updated Contents]
v00.01.02.00.00  2023/11/2
1. Self calibration optimization update
2. Solve the problem of UltraLab startup connection failure
3. Solve the problem of failure to save waveform in wfm format
4. Add education model equivalent settings
5. Solve the problem of unresponsive touch on startup screen
v00.01.01.00.02  2023/09/12
2. Update Help Documents
Download:
https://alc-sh-wwwdownload.oss-cn-shanghai.aliyuncs.com/cn/Firmware/Digital%20Osscillscope/DHO800%26DHO900/DHO800_DHO900(Software)Updatev00.01.02.00.00.zip
The following users thanked this post: Serg65536
Online RAPo
« Reply #1705 on: November 16, 2023, 04:47:16 pm »
What is point 4?
Online Martin72
  • Testfield Technician
« Reply #1706 on: November 16, 2023, 06:00:07 pm »
No idea, but but one thing in advance:
I have just installed the latest firmware - The hacks remain... ;)
Just for info.
(Kierkegaard)
The following users thanked this post: Serg65536, RAPo
Offline Serg65536
  • Country: ua
« Reply #1707 on: November 16, 2023, 06:17:35 pm »
Download:
Where do you get this info?
On the international site it is 1.00 still.
On the rigolna.com the latest firmware is 1.01
Offline Fungus
« Reply #1708 on: November 16, 2023, 06:25:29 pm »
Just for info.
Can it calibrate itself as a DHO900 now?
Offline Fungus
« Reply #1709 on: November 16, 2023, 06:35:01 pm »
Quote from: rigol
So... none of the bugs we've been reporting here or anything really worth having?  :(
A minor update that wasn't released?
Download:
From Aliexpress??
Offline bulba99
« Reply #1710 on: November 16, 2023, 06:43:56 pm »
Online Martin72
« Reply #1711 on: November 16, 2023, 07:04:47 pm »
Do you mean the offset problem we had when we installed the 900 vendor ?
I haven't tried it yet, I was busy with the ultra acquire.
(Kierkegaard)
Offline Fungus
« Reply #1712 on: November 16, 2023, 09:34:49 pm »
Yes. Release notes say there have been two changes to the calibration code. Maybe that got fixed.
Online Martin72
« Reply #1713 on: November 16, 2023, 10:12:39 pm »
I'm currently running the self-calibration on mine, I've only updated the firmware, but that was probably enough to give me an offset on each channel.
(Kierkegaard)
Online ebastler
« Reply #1714 on: November 16, 2023, 10:14:05 pm »
Did they fix any of the bugs reported here on the forum? If the release notes actually list all changes, it seems that the answer is "no". Maybe they have done more than what the notes say; wouldn't be the first time. Or maybe they just don't read this forum.  :(
Online Martin72
« Reply #1715 on: November 16, 2023, 10:28:13 pm »
Finding bugs only started a few weeks ago, when the first scopes were available in the rest of the world.
They can't implement it that quickly.
I'm currently thinking about whether I shouldn't throw the new firmware down again - self-calibration failed, new attempt...
(Kierkegaard)
Offline dmulligan
« Reply #1716 on: November 16, 2023, 10:32:05 pm »
I don't blame them for not reading this forum.  The signal to argument ratio far is too low in every DHO800/900 thread.
Online Martin72
« Reply #1717 on: November 16, 2023, 10:44:28 pm »
They also have their people here, they just don't make an active appearance.
(rigol.eu support, for example, was always well informed, at least that was the case in 2020)
(Kierkegaard)
Online Martin72
« Reply #1718 on: November 16, 2023, 10:50:16 pm »
Hands off the firmware update!
The second attempt also failed.
Tomorrow I will see if I can downgrade again.
(Kierkegaard)
Offline Fungus
« Reply #1719 on: November 16, 2023, 11:01:37 pm »
The firmware is an Aliexpress special?
Downgrading works just fine on these... I've done it a few times.
Online Martin72
« Reply #1720 on: November 16, 2023, 11:14:01 pm »
Yepp, couldn´t wait until tomorrow... ;)
Now the self-cal runs....let´s hope.
Hmm....looking a the message in the pic again, ADC core order...0-7 ? Eight cores??
(Kierkegaard)
Online Martin72
« Reply #1721 on: November 16, 2023, 11:26:44 pm »
Final proof that the linked firmware is CRAP, Hands off !!! :scared:
After downgrading self-cal is OK.
« Last Edit: November 16, 2023, 11:33:14 pm by Martin72 »
(Kierkegaard)
Offline Fungus
« Reply #1722 on: November 16, 2023, 11:28:35 pm »
The bugs thread is quite good.
Offline Serg65536
  • Country: ua
« Reply #1723 on: November 17, 2023, 11:49:08 am »
You should try to push old *.cal files before doing the first cal on 1.02 firmware.
And now you can use DHO924 vendor.bin with (almost) no offset and high voltage precision. :)
Offline Serg65536
  • Country: ua
« Reply #1724 on: November 17, 2023, 01:02:11 pm »
I have a good experience with the 1.02 FW (DHO800 CN page or direct link)
1) Now I can use DHO924 as a main firmware, zero offset could be removed by the calibration. And the voltage accuracy is great also.
2) Now ADC Gain self test is turned on by default.
3) AFE zero self cal procedure increases the DC offset badly. To restore it you can push old cal files and repeat default calibration.
Now it's time to hack it more. 8)
PS: push original old *.cal files (without default *.cal files), if your calibration fails.
The following users thanked this post: Mechatrommer, Menmo1
