Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 316283 times)
Online Fungus
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #1650 on: October 31, 2023, 07:52:00 pm »
I'm calling "fake" on that. You don't need a VESA arm when there's that much space.
Where's all the piles of junk and half-finished circuits? That workbenchlooks like it belongs in the "Stock Electronic Image FAILS" thread.
Offline mawyatt
« Reply #1651 on: October 31, 2023, 08:06:35 pm »
You mean like this cluttered bench!! If the DHO824 was ours, we would get a VESA mount for sure!!
Darn it, now everything's going to fall |O
Best,
« Last Edit: October 31, 2023, 08:08:35 pm by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: Mortymore
Online Martin72
  • Testfield Technician
« Reply #1652 on: October 31, 2023, 08:55:37 pm »
It´s called cleaning up, young man. ;)
(Kierkegaard)
Offline 2N3055
  • Country: hr
« Reply #1653 on: October 31, 2023, 09:01:57 pm »
Best,
You moved to Australia?  :-DD
The following users thanked this post: tv84, asmi, Mortymore, Serg65536, mawyatt
Online tv84
  • Country: pt
« Reply #1654 on: October 31, 2023, 10:24:11 pm »
Nope, it was Rob that rented him some space. That's why he now needs the VESA to hold all the stuff. Since I'm in the antipodes, I'll be taking shelter...  :)
Offline 2N3055
  • Country: hr
« Reply #1655 on: November 01, 2023, 12:16:01 am »
 :-DD :-DD
But if you think about it, that is a good way to prevent dust on your equipment.  You cut some wire, whoosh, falls away from the desk...
Self cleaning...Nice!!
« Last Edit: November 01, 2023, 12:17:57 am by 2N3055 »
Offline mawyatt
« Reply #1656 on: November 01, 2023, 01:31:37 am »
Well we did want to use a negative supply circuit and see the DHO824 slow rolling screen running left to right to see time reversed so we could view those non-causal Gibbs Ears!! Now we have to stand on our head to read the numbers on the DMMs since they are negative and too hard to read upside down  :wtf:
Best,
Offline tautech
« Reply #1657 on: November 01, 2023, 09:13:55 am »
Are you ? Come visit.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #1658 on: November 01, 2023, 11:51:54 am »
few pages of very on topic unbox and teardown.. 8)
Offline milamber
« Reply #1659 on: November 03, 2023, 09:52:55 am »
Well, coming from a DS1054z I guess I will save my money and just replace it by the Rigol DHO804 while prices are still high for the old unit.
But I am just curious about the linear USB power supply.
Are effects worth than with the internal one of a DS1054z?
Offline ebastler
« Reply #1660 on: November 03, 2023, 10:21:34 am »
Not sure what you are referring to with the "linear USB power supply"? The DHO800/900 scopes come with a regular USB-C power supply, which is a switching supply capable of negotiating the right voltage. (DHO requests 15V.) Rigol currently ships Lenovo or LiteOn supplies.
There were some discussions whether power-supply noise might be leaking into the scope, but experiments with a linear supply showed no major change: https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg5139402/#msg5139402
Online csuhi17
  • Country: hu
« Reply #1661 on: November 03, 2023, 10:48:02 am »
Not 12V 4A?
Fnirsi oscilloscope = waste&regret
Offline milamber
Online Martin72
« Reply #1663 on: November 03, 2023, 11:36:08 am »
Note that I was looking for the cause of the "ripple" on the calibration signal and was able to rule out the power supply.
I don't know where he saw his ripple.
(Kierkegaard)
Offline ebastler
« Reply #1664 on: November 03, 2023, 11:55:52 am »
Not 12V 4A?
Very early units in China were shipped with a fixed 12V supply, and I think that is what the user manual still describes. But all later production units came with the proper USB-C supplies which support Power Delivery negotiation, and the scope negotiates 15V on these according to several user reports. (12V is an uncommon voltage for USB PD -- added later or obsolete now, not sure.)
Online csuhi17
  • Country: hu
« Reply #1665 on: November 03, 2023, 12:34:45 pm »
Not 12V 4A?
Thanks.
Are there any disadvantages if I want to use a 12V power supply? I have a 12V 120W linear power supply. I needed a linear power supply for the two "Micsig" because the wave was nice and clear with only that. The factory power supply is a disaster for me.
Offline Veteran68
« Reply #1666 on: November 03, 2023, 12:42:18 pm »
It's an optional PD voltage, not obsolete. I don't think it's all that uncommon, really. I have several PD chargers & power bricks that support 12V.
The mandatory SPR voltages for PD are 5, 9, 15, and 20. All lower voltages below the max SPR voltage supported by a power supply must also be supported to be PD compliant. 12V being optional, though.
Offline ebastler
« Reply #1667 on: November 03, 2023, 12:59:50 pm »
Is the "disaster" occuring with the MicSig scopes or with the DHO800/900? -- Anyaway, I would not expect any problems using a fixed 12V supply. I assume Rigol moved away from them since the cheap power supply itself sucked and/or had compliance issues, not because the scope cannot deal with the 12V supply. Depending on how the scope generates its internal supply voltages, it will draw a bit more current than on 15V, or run a bit warmer.
[12V is] an optional PD voltage, not obsolete. I don't think it's all that uncommon, really. I have several PD chargers & power bricks that support 12V.
Looks like 12V was specified in PD 1.0, but I can't see it mentioned in the PD 3.0 specification. (Well, in the various extracts I could find online. The full spec must be published somewhere?!) Anyway, I don't mean to argue. Rigol decided to go for 15V, for whatever reason, and the scope obviously run on either 12V or 15V.
Online csuhi17
  • Country: hu
« Reply #1668 on: November 03, 2023, 01:36:17 pm »
The DHO900 has not arrived yet.
Micsig scopes with its own power supply.
Offline TK
« Reply #1669 on: November 03, 2023, 01:49:34 pm »
I also noticed a lot of discussion about the supplied power supply (switching) but nobody commented about the issue that most modern DSO's have internal switching power supplies and I think it is good that the DHO has an external power supply that can be replaced with a linear one if you need cleaner waveforms.  Even the most expensive models have internal switching power supplies.
The following users thanked this post: milamber
Offline Veteran68
« Reply #1670 on: November 03, 2023, 02:47:59 pm »
Oh, I wasn't trying to argue either. Just offering what I'd read from the specs as clarification.
Reference: USB PD Spec Revision 3.2, Version 1.0, 2023-10 (yes, the ink is still wet)
The fixed compliant voltages (5, 9, 15, 20) are described in section 10.2.2 "Normative Voltages and Currents" on starting on page 1038. This the mandatory part (indicated by the directive "...Shall support...") The SPR AVS (Adjustable Voltage Supply) part of the spec describes the ranges that supplies can optionally support. Section 10.2.3 "Optional Voltages/Currents" on page 1048 indicates two categories:
"Optional Normative Fixed, Variable, and Battery Supply" includes the statement "May Optionally supply additional Voltages and increased currents. However, the Optional Voltages Shall Not exceed 9V."
"Optional Normative SPR Programmable Power Supply" (aka PPS) states "The Max Voltage Shall Not exceed 21V while in SPR mode."
12V isn't called out specifically as it falls within the acceptable PPS range. Technically, a source and sink could negotiate 13.2V or any other odd value within the acceptable range as long as they meet the power constraints.
Section 10.2.2.2 (pages 1045-1047) describe the valid AVS operating ranges for different power configurations.
Example:
Pages 1049-1050 list examples of "what a power adapter that Advertises a particular PDP Rating May offer:"
2) PDP 36W implementation includes:
o 5V @ 3A,
o 9V @ 3A,
o 15 @ 2.4A,
o SPR AVS with 9V – 15V @ 2.4A,
o 9V Prog @ 3 A, and
o 15V Prog @ 2.4A.
There is an example of 12V negotiation specifically mentioned in the B appendices (pg 1069-1070, pg 1074) where various example negotiation scenarios are described, including a Tablet that attempts to negotiate 12V:
And a laptop negotiating with an attached USB hub:
« Last Edit: November 03, 2023, 02:50:34 pm by Veteran68 »
The following users thanked this post: thm_w, ebastler, Mortymore
Online zrq
« Reply #1671 on: November 03, 2023, 04:49:03 pm »
How do you guys in the Europe get your DHO800/900? I ordered from Batronix and they tell me the ETA will be mid-December  :palm: .
« Last Edit: November 03, 2023, 04:50:58 pm by zrq »
Offline ebastler
« Reply #1672 on: November 03, 2023, 05:00:31 pm »
Depends on the specific model, I guess. DHO914 is supposedly in stock at Batronix, and lead times for DHO800 are shorter than other DHO900 models. Other dealers might have different stock? The socially accepted method in Europe is to check dealers' websites for stock/lead time info, or call them or send an email if that info is not provided online.  ;)
Are you really in China as your country flag suggests? Why would you order from Europe then?  ???
Online Fungus
« Reply #1673 on: November 03, 2023, 05:45:33 pm »
I got my DHO804 from Batterfly (Italy).
Online Fungus
« Reply #1674 on: November 03, 2023, 05:47:22 pm »
So everybody is going for the DHO900? That's interesting...
Is it the color? The bandwidth? The Siggen?
