Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 331059 times)
Offline ebastler
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #1350 on: October 10, 2023, 04:14:08 pm »
Offline Cees
« Reply #1351 on: October 10, 2023, 05:58:32 pm »
It was about the ext trigger function
The following users thanked this post: ebastler
Offline Malmen
« Reply #1352 on: October 10, 2023, 06:06:52 pm »
Thanks, will try after it will arrive :)
And have someone tried that battery pack?
https://www.youtube.com/watch?v=MbBq1AVIQAc&pp=ygUOZGhvODAwIGJhdHRlcnk%3D
Funkar fint med vilket 12 volt som helst. Jag kör med ett 4S Lifepo4 pack som ger runt 13 volt. Köpte en USB-C kabel på Biltema och satte dit kontakter som passade mitt RC batteri. Skaffade även en batteriövervakare som larmar om någon cell börjar bli för låg.
Offline ebastler
« Reply #1353 on: October 10, 2023, 06:23:53 pm »
If you don't get your reply in directly after the post you refer to, please insert a (partial) quote of that post to make it clear which post you are responding to. Simply use the "Quote" link instead of the "Reply" link, and shorten the quote manually in the editor if it is excessively long.
The following users thanked this post: Cees
Offline dmulligan
« Reply #1354 on: October 10, 2023, 06:55:48 pm »
Has anyone checked if the USB-C power connector has data too?  Can we power the scope through a powered hub with our USB devices connected to that hub?
Offline power1001
« Reply #1355 on: October 10, 2023, 11:39:31 pm »
Just got my 802 from AliExpress.  Great functionality.  I can’t get the cursors to show up on the FFT window.  Dave’s review had them on the FFT window along with the measurements.  The cursor button will add them to waveform view but doesn’t add to FFT window even when it’s full screen.  What am I doing wrong?
« Last Edit: October 10, 2023, 11:45:45 pm by power1001 »
Offline Serg65536
  • Country: ua
« Reply #1356 on: October 11, 2023, 07:47:56 am »
Rigol DHO800 Aliasing effect
It's not a bug, but could be fixed. Press "Default", use 12.5 MHz (or 25, 20, 10, 5 MHz), 1k memory depth, increase the timebase until aliasing appears. Firmware version 1.00.
https://youtu.be/D_kHEUk-zKo
Offline TurboTom
« Reply #1357 on: October 11, 2023, 08:12:40 am »
This will only work for configurations where the aliasing is caused by the display engine of the scope, i.e. the sampling setup still meets the Shannon requirements. If the acquisition engine causes the aliasing, the "hardware" frequency counter won't help you since its signal is derived "digitally" from after the ADC as I have demonstrated here: https://www.eevblog.com/forum/testgear/rigol-dho804-test-and-compare-thread/msg5106558/#msg5106558
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #1358 on: October 11, 2023, 03:54:16 pm »
I had a quick play with one at the EDS  show today.
UI seemed very responsive.
Smaller than I was expecting, I think maybe a little too small for the amount of stuff on the screen - not good if you have trouble reading small text.
The same scope with a bigger screen would probably have a market.
Slightly disconcerting thing was that normally on a scope you expect to see a little "grass" of noise on a live trace which confirms it's running as opposed to waiting for trigger - the combination of the 12 bit ADC and small screen meant that it was sometimes impossible to see any difference between a live trace and a frozen one - there is a fairly clear trigger indication at the top-left of the screen which I'm sure you'd get used to.
Day Job: Mostly LEDs
Offline Fungus
« Reply #1359 on: October 11, 2023, 05:41:48 pm »
You mean like the DHO1000?  :popcorn:
I'm wondering if the price of those will drop once the DHO800 supply situation settles down.
Maybe also a version of that with logic analyzer will also appear and replace the MSO5000.
Offline ebastler
« Reply #1360 on: October 12, 2023, 06:47:54 am »
On my trusty DS1054Z I love Peter Dreisiebner's "Bildschirmkopie". Triggering the capture right from the PC, then either copy/pasting it right into a document or saving it under a meaningful name (which I can enter using an actual keyboard!) is a great workflow for my taste. And it is really snappy, especially over the USB connection.
Peter, who is active as "PeDre" on this forum, mentioned a while ago that the program should also work with the MSO5000 series, since Rigol's SCPI commands are pretty consistent across their product lines. So it might work with the DHO series too? If it doesn't, maybe Peter is willing to consider requests.  ;)
Bildschirmkopie has been stable for a few years now. It can still be downloaded from Peter's website: https://www.dreisiebner.at/temp/rigol-bildschirmkopie.zip
Quick follow-up on my own post: I just saw in another thread that "Bildschirmkopie" does not work with the DHO series so far. PeDre has replied with a possible fix, but that is yet to be confirmed: https://www.eevblog.com/forum/testgear/rigol-screen-capture-vcl-windows-application/msg5108583/#msg5108583
Offline Fungus
« Reply #1361 on: October 12, 2023, 10:54:20 am »
Mine's arrived at my city but today is a public holiday(*) so I guess I'm not getting it today.
(*) The second one this week - that's Spain for you.
Offline Cees
« Reply #1362 on: October 12, 2023, 11:49:26 am »
Working fine here with the 924S
Offline bulba99
« Reply #1363 on: October 12, 2023, 01:31:20 pm »
New firmware:
v00.01.01.00.01  2023/08/10
1. Remove all time-related displays on the instrument
2. To modify the vertical interface, click the wiring diagram to modify the AC coupling function
3. Modify the delayed scan Chinese display as Zoom
4. Modify the order of the menu in the upper right corner, put the measurement in the front and Default in the back
5. The probe ratio interface is removed, and the probe ratio option is added to the vertical first-level menu
https://supportcn.rigol.com/Public/Uploads/uploadfile/files/ftp/Firmware/DHO800_DHO900(Software)UpdateV00.01.01.zip
The following users thanked this post: thm_w, Fungus, ebastler
Offline ebastler
« Reply #1364 on: October 12, 2023, 01:55:54 pm »
Thanks, nice find!
I assume the "remove all time-related displays" refers to the time of day, which was rather meaningless without a battery-buffered clock. Otherwise, none of the issues mentioned in the bug-report thread here on the forum seems to be addressed yet. But good to see that Rigol does have someone working on the firmware; let's hope for a next release soon.
Offline 2N3055
  • Country: hr
« Reply #1365 on: October 12, 2023, 02:01:33 pm »
Thanks, nice find!
And we can see where they are still experimenting with GUI features and positioning...
Let's hope they will listen closely to user base and make note..
Offline Fungus
« Reply #1366 on: October 12, 2023, 03:52:32 pm »
New firmware:
Just in time! Mine should arrive tomorrow...  :)
Offline tv84
  • Country: pt
« Reply #1367 on: October 12, 2023, 04:00:25 pm »
New firmware:
They knew that.  :)
Offline bulba99
Offline TimFox
« Reply #1369 on: October 12, 2023, 04:16:12 pm »
Has anyone tried the Bode Plot function yet after this update?
Offline Fungus
« Reply #1370 on: October 12, 2023, 04:18:58 pm »
It's only been out for a few hours!
Offline TimFox
« Reply #1371 on: October 12, 2023, 04:19:39 pm »
Yes, but young people these days are faster than I am.
Offline ebastler
« Reply #1372 on: October 12, 2023, 04:29:28 pm »
There's a thread for that! ;)  And didn't you already thank Cees, who stated there that it is fixed? https://www.eevblog.com/forum/testgear/rigol-dho914s-bode-plot/msg5109180/#msg5109180
Offline TimFox
« Reply #1373 on: October 12, 2023, 05:11:09 pm »
Yes, I thanked him for the link to the update.
My update is now in process.
Offline TimFox
« Reply #1374 on: October 12, 2023, 06:54:57 pm »
My new Bode plot after update:  https://www.eevblog.com/forum/testgear/rigol-dho914s-bode-plot/msg5109597/#msg5109597
I am still disappointed.
