Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 316336 times)
0 Members and 18 Guests are viewing this topic.
Offline dreamcat4
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #1225 on: September 30, 2023, 09:12:51 pm »
it cannot be too hard to cut a piece of plastic and make a plug yourself. or use a found object. or to take a spare idc lying about and shove a hot glue gun in to it. then peel out the resulting 'vaguely rectangular' mess. or do the same with a neutral cure silicone sealant. or perhaps something else with just spacers or gaps being hollowed out. but to grab into the internal corners of the idc on the scope.
any 1 of numerous ways and you can fashion something appropriate. so long as it does not adversely accumulate static charges / discharges into the pins on the scope side. or otherwise cause something undesirable effect.
Online Martin72
  • Testfield Technician
« Reply #1226 on: September 30, 2023, 09:35:50 pm »
cut front panel is easy, soldering bga is risky for me... so i'll leave it like that.. better not having LA than loosing the whole DHO...
I can't really imagine that there could be people who, in order to "save" 200 bucks(DHO804-->DHO914), would tinker with their scope by cutting holes in the case and soldering around the circuit board.
(Kierkegaard)
Offline Fungus
« Reply #1227 on: September 30, 2023, 09:51:07 pm »
This is 2023, use a 3D printer!
Offline 2N3055
  • Country: hr
« Reply #1228 on: September 30, 2023, 09:56:21 pm »
People do all kinds of things...
The following users thanked this post: nctnico, tv84, DaneLaw
Online TimFox
« Reply #1229 on: September 30, 2023, 09:58:14 pm »
I asked for a simple commercially-available part, since I don't own a 3D printer.
The simple connector suggestion is reasonable.
Offline Serg65536
  • Country: ua
« Reply #1230 on: September 30, 2023, 10:01:27 pm »
Rigol DHO804 DHO800 random lines BUG
Frequency 188.1 kHz, increasing the time scale until random lines appear in the waveform window. Further timebase increase leads to waveform disappearance.
Firmware version 1.00. Roll mode off.
UPDATE: I can't reproduce this bug anymore. Maybe it was some fault due to extensive multiple hour testing, or simply I've should press the "Default" button, but now I don't know how to make it.
« Last Edit: October 02, 2023, 05:24:10 pm by Serg65536 »
The following users thanked this post: EEVblog, Kean, DaneLaw, Mortymore, Anthocyanina
Online Martin72
« Reply #1231 on: September 30, 2023, 10:12:00 pm »
@Serg65536:
Interesting and important videos - I think it would be better to place them in a new thread, perhaps a "Rigol DHO Bugs(?)" titled one.
Here they will get lost...
OMG... :palm:
(Kierkegaard)
Offline LinuxGuy123
« Reply #1232 on: October 01, 2023, 01:15:11 am »
Excuse my ignorance, but what is the difference between the DHO800 and the MSO5000 series ?  Other than bandwidth.
I will be needing a built in logic analyzer.   A signal generator would be handy too.  Will Rigol be making a DSO800 with a LA ?
Thanks
Online Martin72
« Reply #1233 on: October 01, 2023, 01:33:00 am »
Read and compare their specs, to be found on the rigol website.
They already did - DHO900 series.
(Kierkegaard)
The following users thanked this post: mwb1100
Offline Fungus
« Reply #1234 on: October 01, 2023, 01:59:04 am »
They're completely different beasts. Too many differences to list here.
They already did: https://www.rigolna.com/products/rigol-digital-oscilloscopes/dho900/
Offline sanman
« Reply #1235 on: October 01, 2023, 02:27:43 am »
I received my unit on Friday and mounted it on a cheap Amazon arm. I really like it. Small and easy to move around as I work.
Offline mawyatt
« Reply #1236 on: October 01, 2023, 02:55:24 am »
Nice, looks great.
What mount did you use?
Best,
~Wyatt Labs by Mike~
Online KungFuJosh
  • TEAS is real.
« Reply #1237 on: October 01, 2023, 03:00:53 am »
That's cool! Adding VESA mounts on the back is the smartest thing I've seen from Rigol.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline ebastler
« Reply #1238 on: October 01, 2023, 04:48:57 am »
It's really buggy in the stop mode. Waveform frequently disappears all the way through. It's hard to move and analyze signal.
Thanks for finding and publishing these. I agree with Martin72 that these posts should be moved to a separate new thread like "Rigol DHO Bugs(?)" to make sure they don't get lost in the noise. I will ping the moderators and suggest that they move the posts, OK?
For some other scopes we have/had "bug list" threads where the first thread contains a loist of known as well as fixed bugs. Maintaining it is ongoing work for the original poster though -- if you want to do this, many thanks in advance!
Offline ebastler
« Reply #1239 on: October 01, 2023, 05:07:51 am »
Wouldn't be for me either. With the DHO800/900 series, the only "hack" worth doing is the bandwidth upgrade from DHO804 to 814, in my opinion. With the DHO900 models, you get actual hardware upgrades for every increment in price, and I think the pricing is reasonable:
  • Logic analyzer port $100 (all DHO900 models)
  • Signal generator $100 (DHO9xxS models)
  • Four 350 MHz probes and more bandwidth, although with marginal sampling rate, $100 (DHO924 model)
The only nuisance is that there is no DHO904 model to start with. Hence if one is interested in any of the 9xx features, one actually has to pay an additional $100 (over the 804) for the 125 MHz bandwidth and can't apply any hack...
Offline tv84
  • Country: pt
« Reply #1240 on: October 01, 2023, 07:58:11 am »
 :wtf: Can't beta testing detect this basic thing?  :palm: :palm: :palm: What type of quality control do these guys have in place?
Online Kleinstein
« Reply #1241 on: October 01, 2023, 08:26:59 am »
The random lines exceeding the normal range is indeed odd. It happens in a range where on would normally expect aliasing to start (e.g. 190 kHz signal and 250 kSPS) - still there should be no higher values / amplitudes. This may be an artifact of the reconstruction filter.
With the even lower sampling rates it looks like there is no trigger - like trying to trigger from the digitized signal (which can be a good thing and is prised by some of the better scopes as a good feature). I don't mind not getting a aliased signal. Ideally there would be a warning if too much of the signal is suppressed by averaging / downsampling. Still this would be a feature I have not yet seen on any scope.
Offline 2N3055
  • Country: hr
« Reply #1242 on: October 01, 2023, 10:07:25 am »
I warned people that Rigol released alpha stage software. First adopters are beta testers. Just keep reporting as much as you can so it gets fixed, nothing else to do. But hey, when R&S  released RTB2000 it was not much better.
Offline ebastler
« Reply #1243 on: October 01, 2023, 11:37:40 am »
They might have approached it as "Hey, it's all proven out in the DHO1000 and 4000, so we can go light on the testing"...  ::)
Given the fact that it is derived from the larger DHO models, I wonder where those errors crept in. The FPGA is the main difference from the DHO1000 I believe, while the DAC and the microprocessor/SOC are the same? Seems conceivable that differences in the FPGA data processing are causing the bugs.
Offline Fungus
« Reply #1244 on: October 01, 2023, 11:37:47 am »
The DHO1000 has had recent firmware updates that fix (among other things):
- Truncation problem of enlarged waveform after stopping
- Data abnormality at the end of the high-resolution mode waveform
So... maybe these bugs are already fixed internally and they just need releasing for the 800/900.
The following users thanked this post: ebastler
Offline ebastler
« Reply #1245 on: October 01, 2023, 11:45:13 am »
"Recent" firmware updates? So it took them about a year to notice and fix these in the DHO1000? Not sure whether I find that reassuring...
Offline Fungus
« Reply #1246 on: October 01, 2023, 12:00:53 pm »
Haters gonna hate.
Offline ebastler
« Reply #1247 on: October 01, 2023, 12:11:24 pm »
Haters gonna hate.
Come on, man. I have been a happy DS1054Z user for 8 years or so, and have expressed a keen interest in upgrading to the DHO900 series in this and another thread. Certainly not a Rigol hater...
What is your take on Rigol's responsiveness in addressing bugs? If those bugs fixed "recently" in the DHO1000 are indeed the pretty glaring ones described by Serg65536, are you impressed?
Offline tszaboo
« Reply #1248 on: October 01, 2023, 12:50:41 pm »
Honestly, I don't think it's that difficult. The front panel is covered by a label, you make a nice cover for it from PC, paper or carbon fiber or whatever, and then your plastic cutting skills won't even show.
I really don't think the bigger models are worth it. There are better models at the same price, or just slightly above. The price all adds up. Plus this thing is tiny, I would much rather have a bigger scope with bigger screen and more buttons and features. You know the ones that you only need few times, but if you don't have it...
BTW did we figure it out already if the 12 bitis just a marketing gimmick or actually useful on this scope?
Offline ebastler
« Reply #1249 on: October 01, 2023, 12:58:55 pm »
Which competing model(s) with logic analyser and /or signal generator would you consider?
The portability is a plus for me; I do travel with the scope occasionally. For use at home I would add an external touch screen, 14" or so,  if I find the display too small. I have not run into missing features with my DS1xx4 over the years, hence am not concerned on the front. (But might not know what I am missing...)
