Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 350520 times)
Online ataradov
    • Personal site
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #25 on: July 18, 2023, 11:12:31 pm »
Nope. Type-C can output many different voltages. You can negotiate with the supply and tell it how many volts you want.
Have you seen pictures of this power supply? Linear (?) Voltage regulator on the output is the most advanced device there. There is nothing that can negotiate. They are just seeding output voltage as is.
There are not even wires to negotiate over. They just have two voltage wires and that's it. It is hilariously non-compliant implementation.
I really hope it is just a temporary hack, because even the label on that power supply makes no sense. They just took cheapest PSU they could find and slapped USB-C connector on it.
« Last Edit: July 18, 2023, 11:19:05 pm by ataradov »
Alex
The following users thanked this post: Someone, Towger, thm_w, tooki, Scottie
Offline Martin72
  • Testfield Technician
« Reply #26 on: July 18, 2023, 11:17:49 pm »
Quote from: thm_w
No way the real scope would ship with that.
Agree to this.
Nevertheless, a nice and clear 7" touchdisplay, 6-core cpu, hdmi output, 12 bit, same adc´s as the bigger ones...
This scope will blast everything else away in it´s priceclass.
(Kierkegaard)
Online ataradov
    • Personal site
« Reply #27 on: July 18, 2023, 11:21:10 pm »
I would wait to see performance and general feel of the UI running Android.  It might not be great negating any positives of the hardware.
Alex
Offline Martin72
« Reply #28 on: July 18, 2023, 11:48:14 pm »
Batronix lent me an HDO4204 for testing in February this year for just under 3 weeks (I reported), so I know roughly what to expect. 8)
(Kierkegaard)
The following users thanked this post: egonotto, thm_w
Offline Fungus
« Reply #29 on: July 19, 2023, 07:38:08 am »
Oh, I didn't look closely. Yeah, no data wires so no negotiation.
Agreed. I don't know where OP got the 'scope from but there's simply no way. It's not even Rigol branded.
I really hope external power supplies don't become a thing. Who cares if your product is small if you still have to carry random stuff around.
It's no worse than carrying a chunky IEC power cord.
This scope will blast everything else away in it´s price class.
Yep, I'll be getting one when they appear.
Offline AzusaTopic starter
  • Country: cn
« Reply #30 on: July 19, 2023, 10:46:09 am »
The original power supply is output 12v over typeC directly. It's a non compliant product sure.
It‘s offically did. All first batch of this series scopes are come with it whether where you buy.
I don't know why rigol provide this. It's not as good as let customers purchase the unoffically power supply separately.
but rigol said they will reissued a new power supply for first batch customer later.
  • Country: cn
« Reply #31 on: July 19, 2023, 10:59:59 am »
There are the first batch unbox video from customers on bilibili.
https://www.bilibili.com/video/BV1YP411k7Tw/
https://www.bilibili.com/video/BV1Dz4y1776C/
https://www.bilibili.com/video/BV1ox4y1R7qj/
https://www.bilibili.com/video/BV1Lz4y1E7bt/
It's all comes with this power supply even DHO900 series.
  • Country: cn
« Reply #32 on: July 19, 2023, 11:15:29 am »
It should nearly like DHO1000/4000.The same android 7.1.2 and the same RK3399.And may same software?
Anyway,the options hacking way are the same with DHO1000/4000.The Key.data and SCPI,and only need to modify the model as DHO800 or DHO900 on the golang script.
Offline slavoy
« Reply #33 on: July 19, 2023, 11:56:51 am »
Wow, it's so tiny. You can hold it in hands almost like a scopemeter :D
Offline Fungus
« Reply #34 on: July 19, 2023, 12:24:10 pm »
Looks like a perfect form factor to me.
« Last Edit: July 19, 2023, 05:07:32 pm by Fungus »
Offline Fungus
« Reply #35 on: July 19, 2023, 05:06:49 pm »
I can't imagine other countries will allow the import of those power supplies. 12V into a USB-C connector is a big no-no. I hope nobody tries to use one to charge their phone.
(And beware of grey imports  :scared: )
Offline tv84
  • Country: pt
« Reply #36 on: July 19, 2023, 05:44:56 pm »
 :wtf: USB Power Delivery 1.0 has 2 profiles with 12V. All via USB-C. Can't see where the no-no is.
I have a Lenovo with a power supply that allows, among others, those profiles.
Online ataradov
    • Personal site
« Reply #37 on: July 19, 2023, 06:05:51 pm »
Read the beginning of the  thread and look at the power supply shown here. It just sends 12 V without negotiation.
Alex
Offline tv84
  • Country: pt
« Reply #38 on: July 19, 2023, 06:10:56 pm »
Of course that's unacceptable and dangerous. But Fungus ended up with a generic quote about USB-C and 12V which is, at least, misleading.
Offline Fungus
« Reply #39 on: July 19, 2023, 06:20:20 pm »
I assumed people would have read the post a couple above mine.
Here's the pic, in case anybody else was confused:
12V directly into a USB connector. No data lines, no negotiation.
(not to mention what looks like a simple linear regulator)
I assume the Export versions won't have that.
« Last Edit: July 19, 2023, 06:23:50 pm by Fungus »
The following users thanked this post: BillyD
Offline chronos42
« Reply #40 on: July 19, 2023, 07:40:02 pm »
it is a diode, not a linear regulator. (Makes this thing not better, of course)
Offline svetlov
  • Country: ru
« Reply #41 on: July 19, 2023, 09:36:58 pm »
type C! but then you can power it from the power bank :)
It seemed to me, or does phosphor emission-ultravision not work satisfactorily on these new 12-bit oscilloscopes?
Offline Veteran68
« Reply #42 on: July 20, 2023, 12:06:29 am »
If it were true Type C, then yes you could. The way this is wired, any power bank will only feed it 5V 2A max as there's no data lines to negotiate anything else.
Online ataradov
    • Personal site
« Reply #43 on: July 20, 2023, 12:55:25 am »
There is hope that the hardware in the scope would actually at least attempt to negotiate if there is something on the other end, but also would accept 12 V directly from a dumb power supply.
I really see no point in abusing USB-C like that. The PSU here must be a very temporary solution.
Alex
The following users thanked this post: Someone, thm_w, mwb1100
Offline Fungus
« Reply #44 on: July 20, 2023, 05:50:48 am »
Rigol's web site says you can use a powerbank.
That's only the power supply output. How do you know what's inside the scope?
  • Country: cn
« Reply #45 on: July 20, 2023, 07:22:49 am »
The device has a HUSB238 PD sink contorller.just only the original power supply is 12v directly.
but the output is 15V when i used PD power supply on this device.
The following users thanked this post: thm_w, Kean, Fungus, UK, Scottie
« Reply #46 on: July 20, 2023, 09:06:39 am »
That's clearly an SMPS, what linear supply would have a reservoir cap on the transformer primary?
« Reply #47 on: July 20, 2023, 09:15:53 am »
And a shitty one too without common mode chokes or X and Y class caps.
Offline nctnico
« Reply #48 on: July 20, 2023, 09:21:35 am »
That is perfectly defined. USB-C goes to 48V @5A (and some push 6A) nowadays. But Qualcom has their own charging standard which uses D+/D- lines and this standard also goes to 12V (or even more) at several amps through regular USB connectors. It is all about detecting what kind of device is connected.
Actually there is a capacitor across the mains and it looks like this PSU does something clever to filter the harmonics going into the mains. In the end it doesn't matter for as long as the PSU passes CE / FCC limits.
« Last Edit: July 20, 2023, 09:27:53 am by nctnico »
Offline Martin72
« Reply #49 on: July 20, 2023, 09:44:19 am »
As long it does, exactly.. ;)
Does anyone believe that ?
(Kierkegaard)
