Can anybody recommend a known model of WiFi dongle that works with these?
Also be careful with TP-Link TL-WN725N which someone advised as compatible, since it has 3 versions... V1 uses RTL8188CUS, and V2/V3 use RTL8188EUS
0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
I'd appreciate it if someone who already has DHO900 with LA and caliper could make four precise measurements. #3 and #4 are the distances between the front surface of the scope shell and the plastic edge of the IDC socket, both sides should be measured... it seems to me the right side is slightly higher than the left. I'm trying to adapt/design a nice-looking shell of DIY LA for new DHO scopes.
adb shell am start com.android.settings
adb shell am force-stop com.android.settings
Rigol releases new firmware v00.01.02.00.00 for DHO800 / DHO900 ~ 2023.11.16Download:https://alc-sh-wwwdownload.oss-cn-shanghai.aliyuncs.com/cn/Firmware/Digital%20Osscillscope/DHO800%26DHO900/DHO800_DHO900(Software)Updatev00.01.02.00.00.zip
No idea, but but one thing in advance:I have just installed the latest firmware - The hacks remain... Just for info.
v00.01.02.00.00 2023/11/21. Self calibration optimization update2. Solve the problem of UltraLab startup connection failure3. Solve the problem of failure to save waveform in wfm format4. Add education model equivalent settings5. Solve the problem of unresponsive touch on startup screen
v00.01.01.00.02 2023/09/121. Self calibration optimization update2. Update Help Documents
Can it calibrate itself as a DHO900 now?
Quote from: Fungus on November 16, 2023, 06:25:29 pmCan it calibrate itself as a DHO900 now?Do you mean the offset problem we had when we installed the 900 vendor ?
Or maybe they just don't read this forum.
Hands off the firmware update!The second attempt also failed.
Tomorrow I will see if I can downgrade again.
I don't blame them for not reading this forum. The signal to argument ratio far is too low in every DHO800/900 thread.
Final proof that the linked firmware is CRAP, Hands off !!! After downgrading self-cal is OK.
