Thanks gentlemen.
Of course, the whole community formum will not open the oscilloscope.
First Colleague Pepek - on your photo pcb writes DS2000?
2 Do looks the same pcb board MSO 2072? I am your scobe jescze not opened.
3 Is the JTAG as below can be taken?
4 How to do it under Linux?
5 What are the commands you need to type?
Waiting for a description of how to do it step by step through JTAG.
Thank you
1 Support 1.5V, 1.8V, 2.5V, 3.5V and 5.0V.
2nd Support all ALTERA products: CPLD (MAX3000A, MAX7000 devices, MAX9000 and MAX II); FPGA (Stratix, StratixII, Cyclone, CYCLONEII, ACEX 1K, and FLEX 10K APEX20K); Active serial configuration device (EPCS1, EPCS4, EPCS16)
---- Now we have tested chip using this tool is: Cyclone (EP1C3, EP1C6, EP1C12, EP1C20); Cyclone II (EP2C5, EP2C8, EP2C35); Stratix (EP1S10, EP1S20, EP1S25); Stratix II (EP2S60); FLEX10K (EPF10K10, EPF0K30); ACEX1K (EP1K30); MAX7000 (MAX7128SLC84, MAX7128); AETC100 (MAX3000, MAX3128); MAXII (MAXII240, MAXII570, MAXII1270); EPCS (EPCS1, EPCS4, EPCS16); EPC (EPC1, EPC4)
3 Support AS, PS and JTAG program (with Verify and Bank Check function).
---- When we tested the chip above, the use of the different program mode: JTAG (Cyclone, CYCLONEII, Stratix II, Flex10K, Acex1K, MAX7000 and MAX3000A); AS (EPCS1, EPCS4, EPCS16); PS (Stratix, Stratix GX)
4 Support embedded logic analyzer function of SignalTapII
5 Support NIOS II communication and debugger - When you use it to debug your Black Gold, it will not pop-up warning
6 Faster - about 6 times than ByteblasterII
7 USB interface! - You do not need a PC with serial port now
8 100% compatible with Official ALTERA USB Blaster
