I had that problem when I installed the 'H' version on Win 7 64 bit, and it all came down to the drivers ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I stumbled across these drivers (H version) and after installing the drivers and following Slappy_g's excellent write up am now fully up and running ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
If you try and run the program NOT connected to the JTAG header it will come up with an error mmy WIN essage, but not the TDO stuck one.
Good luck, you will get there eventually!!
Andy
This morning I tried installing everything on my Win 7 64 bit laptop, following Slappy_g's post.
It doesn't find the device at all.
C:\GNU Toolchain\elf\bin>bfin-gdbproxy.exe --debug
Remote proxy for GDB, v0.7.2, Copyright (C) 1999 Quality Quorum Inc.
MSP430 adaption Copyright (C) 2002 Chris Liechti and Steve Underwood
Blackfin adaption Copyright (C) 2008 Analog Devices, Inc.
GDBproxy comes with ABSOLUTELY NO WARRANTY; for details
use `--warranty' option. This is Open Source software. You are
welcome to redistribute it under certain conditions. Use the
'--copying' option for details.
debug: bfin: bfin_open ()
error: bfin: cable initialization failed
^C
This was with the Olimex ARM-USB-OCD connected, but not the DSO.
On the 32 Bit Win 7 laptop it at least finds the Olimex adapter. and appears to connect to it as the LED changes from green to red and it tells me its using the libftdi driver!
Mine is not the H version adaptor.
I get the TDO stuck low error message irrespective of whether its connected to the DSO or not.
