Author Topic: Rigol's New Function Generator and DMM: DG800Pro / 900Pro / DM858  (Read 90579 times)
Offline PELLTopic starter
  • Country: cn
Looks pretty decent to me   :) (not really)
Update: I purchased one about a month ago, and here are some teardown photos
https://www.eevblog.com/forum/testgear/rigol-new-dg822pro-teardown
Currently the software on this is an disaster, so pls don't buy it. :--
Here are some main specs:
DG800Pro: Up to 50M, 625MSa/s, 16-bits resolution, 20 harmonics max.
Starting at $280 (trans from CNY), possible $299 in global
DG900Pro: Up to 200M, 1.25GSa/s,  16-bits resolution, 20 harmonics max.
Starting at $680 (trans from CNY), possible $699 in global
One thing I personally interested is the Amplitude: Up to 20Vpp at high impedence or 10Vpp at 50 ohm  :scared:
Edit: The DMM part I put it on the latest reply in this thread :)
« Last Edit: March 26, 2024, 03:18:34 pm by PELL »
The following users thanked this post: thm_w, TurboTom, Mortymore, Martin72, Markus2801A, tutecnicocarlos, NE666
  • Country: cn
Re: Rigol Just Launch It's New Function Generator: DG800Pro / 900Pro
« Reply #1 on: November 03, 2023, 08:14:20 am »
here is the 900 Pro and some more
The following users thanked this post: tutecnicocarlos
  • Country: cn
« Reply #2 on: November 03, 2023, 08:21:13 am »
Foegot to mentioned :palm: it also comes with a Frequency Counter
DG800 Pro: 7 digits, Up to 500M
DG900 Pro: 7 digits. Up to 1G
Online ebastler
« Reply #3 on: November 03, 2023, 12:27:23 pm »
Nice DHO900 styling -- "collect 'em all!"  ;)
But I will never understand what the Rigol designers were smoking when they introduced those circular number keys. How am I expected to enter numbers there?! What's wrong with the rectangular arrangement used on calculators or phones?! Who wants a lab instrument that looks like a toy? I am flabbergasted that they kept this absurd button arrangement on the new series.
The following users thanked this post: voltsandjolts, Circlotron, Swake, tooki, jusaca, colorado.rob, rifkum, marcus h, slavoy, PELL
Online iMo
  • Country: cv
« Reply #4 on: November 03, 2023, 12:31:31 pm »
Now, how to make Bode with the DHO804+DG800 :)
The following users thanked this post: Mortymore, wolfy007, Martin72, PELL
  • Country: cn
« Reply #5 on: November 03, 2023, 12:45:53 pm »
I think someone can make a Python script using the LAN SCPI to control both instruments and draw a Bode automatically ;)
  • Country: cn
« Reply #6 on: November 03, 2023, 12:51:34 pm »
And I found this Rigol patent from The China Patent Office
The patent name is "DMM", so there might be another DHO-liked product coming soon! :)
The following users thanked this post: Mortymore, iMo, ZhuraYuk, NE666
Offline NE666
« Reply #7 on: November 03, 2023, 10:11:17 pm »
Personally, ridiculous numeric keypad layout aside, I'm very pleased to see this.  Since first sight of the DHO 800/900 series I'd hoped Rigol would leverage the form factor for other instruments.  And, hopefully, here we are and much sooner than expected.
VESA mount and external USB power.  Very bench space friendly, compared to the "shoeboxes" we've been accustomed to for signal generators, counters, bench DMMs etc.
UI consistency with the DHO series suggests that Rigol has settled on Android-based platforms for future development.
Thanks OP for sharing.
Online ebastler
« Reply #8 on: November 03, 2023, 10:32:47 pm »
Rigol should offer a rail for wall-mounting the new instrument lineup, like this Braun/Rams classic.  :)
« Last Edit: November 03, 2023, 10:34:27 pm by ebastler »
The following users thanked this post: tv84, mairo, wolfy007, WoodEGA
Online Martin72
  • Testfield Technician
« Reply #9 on: November 03, 2023, 10:48:17 pm »
Quote from: PELL
I miss the CMOS level output with 15V unipolar in today's generators.
Or a little more "power", e.g. to be able to drive small transformers directly or gates from Mosfets/IGBTs.
Quote from: NE666
I always ask myself what is missing when something is very small.
Quote from: ebastler
Consent.
I like the display and the arrangement, but the right-hand side with the buttons...
I find it confusing and visually unsuccessful, especially when it comes to white letters/numbers on a black background.
Otherwise, "case recycling" is an interesting idea, scope, generator, multimeter, possibly power supply unit, spectrum analyzer...
You then have to take a closer look at which device you need to switch on.
(Kierkegaard)
Offline NE666
« Reply #10 on: November 03, 2023, 11:12:11 pm »
In the good 'ol days of HP, probably a honking great toroidal transformer and with it, a high quality, low noise linear power supply.  But that was never going to happen here.  So all that's really gone is probably yet another generic SMPS.
In my opinion a good few "second tier" instrument manufacturers have just been following suit with accepted cases with bail handle designs for years.  If it shares HP/Agilent aesthetics, it must be as good, right?  It's refreshing to see some innovation and some outside the box (case?) thinking.
Offline thm_w
  • Non-expert
« Reply #11 on: November 03, 2023, 11:18:45 pm »
If you've used a DP832, it works, its not as good as a number pad but it is usable. You easily adapt as the numbers are in order, and A/mA, V, mV are straightforward locations (and are really useful since you can hit '5' -> 'V' as you would type it out). I still agree a normal numpad would be better.
Here? It does seem a wilder of a choice. Where is the V button? Its just M/G/k/hz. So its easy to type in frequency but not easy to enter a voltage.
DG4000 for comparison:
Now on to the real question.. is the hardware of the DG800pro and DG900pro going to be the same?
  • Country: cn
« Reply #12 on: November 04, 2023, 03:29:12 am »
I think most of the parts will be the same. It should based on the RK3399 + ZYNQ + Rigol's own ASIC and running Andriod just like DHO scopes.
About the ASIC, Rigol mentioned it in their release press. It was integrated with wave-gen, amp, variable filters, protection, etc.
So... this thing is likely hackable ;)
But one thing they might do is let the weaker (defected?) ASIC goes into the lower 800 Pro? Not sure though
Anyway, it will be available in China from late November. Hope someone can get one and take it apart. >:D
Offline NE666
« Reply #13 on: November 04, 2023, 08:46:56 am »
it works, its not as good as a number pad but it is usable. ...It does seem a wilder of a choice. Where is the V button? Its just M/G/k/hz. So its easy to type in frequency but not easy to enter a voltage.
*IF* the touch UI is well implemented, it becomes somewhat of a non-issue. If.
Offline NE666
« Reply #14 on: November 04, 2023, 08:49:46 am »
Cue speculation, complaints and 10 pages of hacking suggestions regarding fan noise in 3, 2, ..
The following users thanked this post: Someone, thm_w, ch_scr
Offline NE666
« Reply #15 on: November 04, 2023, 09:01:11 am »
Is anyone able to access the data sheets for these instruments from the international site (rigol.com)?
Links are provided on the product pages but these are currently timing out for me.
The following users thanked this post: PELL
  • Country: cn
« Reply #16 on: November 04, 2023, 12:09:13 pm »
Unfortunately the specs sheets are only avalible in Chinese at RIGOL China website and you need to sign in to download it.
However if you do interested in the specs, I download it and upload to Google Drive here (Chinese Language Only, might need a translator)  ;)
DG800 Pro: https://drive.google.com/file/d/1TOzQ7TxM7RYNXCLkJL1_nGDDlOc7VNua/view?usp=sharing
DG900 Pro: https://drive.google.com/file/d/1P2cEduwfcy9q_PYcQzfVDEr4KNOYMiuy/view?usp=sharing
The following users thanked this post: nctnico, thm_w, Martin72, ZhuraYuk, NE666
Offline idolclub
The following users thanked this post: Martin72, PELL
Online Martin72
« Reply #18 on: November 04, 2023, 12:38:49 pm »
THD<0.1%("Audio  Range")....Not bad.
(Kierkegaard)
Online nctnico
« Reply #19 on: November 04, 2023, 01:21:01 pm »
Unfortunately the jitter specification is not just bad, it is laughably bad. On par with the UNI-T UTG932
« Last Edit: November 04, 2023, 01:30:01 pm by nctnico »
Online 2N3055
  • Country: hr
« Reply #20 on: November 04, 2023, 02:10:20 pm »
Not really spectacular either..
16 bit generator I have has cca. 0.015% THD in audio range at 1V RMS, measured with Pico4262 at 100 Hz, 1 Khz and 10 kHz..
And that is not low distortion audio gen, but a gen purpose AWG.
Distortion on DG800Pro / 900Pro should be measured, this spec is not as good as it should be for 16Bit Gen.
My old DG1000Z (14bit) is close to that.
Low distortion gen in Pico is 0,002-0,003% (90dBc) THD, two orders of magnitude better. And that measurement is limited by scope inputs.
But honestly AWG is not best tool for super low distortion signal anyways.
For general purpose use even 0.1% is more than good enough.
  • Country: cn
« Reply #21 on: November 04, 2023, 02:23:03 pm »
Totally agree, I would expect they can set a new benchmark performance at entry-level market.
Maybe they just can't reach that performance with custom ASIC :-//
Offline MathWizard
« Reply #22 on: November 07, 2023, 08:39:13 pm »
I would like more spacing between the big main digits, or between groups of 3, and bigger decimal's, maybe another rounder font so they don't blend together so much. I think that would be annoying/hard for some people to read even from 3-4ft.
Offline MathWizard
« Reply #23 on: November 07, 2023, 08:50:59 pm »
How do Siglent's compare ? I have a sdg2142x but it's my 1st AWG. I'm thinking about getting a faster 1, upto 500MHz, like the sdg6000 series. Then useless +1GHz models drop a lot in price in the next few years, whatever I get next will probably be my last AWG.
I don't own any Rigol stuff yet, but I do like some of it. But then again I have Siglent scopes, so their AWG pairs with their scopes.
Online Martin72
« Reply #24 on: November 07, 2023, 10:09:27 pm »
Rigol 200ps, UTG932 150ps, SDG2000X 150ps, SDG6000 100ps, SDG7000A 10ps, R&S HMF2550 <1ns...
« Last Edit: November 07, 2023, 10:26:34 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: egonotto, thm_w, wolfy007
