The very last of today...
Copy trigger (decode mode): On the siglent it is obviously (copy from trigger, coppy to trigger), see pic.
Then measuring in general:
First I like the arrangement very much, you tap on the measure window and get a short menu on the left side - really cool
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
But there´s something really annoying with it.
You couldn´t change the measure parameter in it...
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
You have to add a new measure window or remove the "old" and then add one with the wanted parameter, that´s really uncool and something for the wishlist to change.
The demoboard got some signals not only decoding types, runt, glitch, pulse, burst, etc.
Tested all, no issues with it.
And then there is a signal "noisy pwm" for demonstrating the Eres function.
Works perfectly on the rigol.
After all testings I´ve started to measure the update rate, will try to finish it before I must send it back.
What I´ve seen so far is, that the updates are always in "packages" regardless in which acquisition mode the scope is.
Or it is simply updates with "long" blind time inbetween.
The maximum I´ve measured was about 500000 wfms/s, will try it again in one of the next evenings.
Time is running out, can test something else until next wednesday evening, on thursday the scope will be send back.
Edit: BTW, in this time of testing the scope hangs two times.
First the screen becomes dark and a white windows appears with the request to start the "rigol app" again, the second I´ve already seen.
Scope was starting automatically after plug in the mains, boots and then freezes, the power button lit orange.
(Red = Stby, green = on)
