Author Topic: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China  (Read 279468 times)
0 Members and 17 Guests are viewing this topic.
Offline balnazzar
Re: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China
« Reply #450 on: November 07, 2022, 11:17:22 am »
Delivery time about 1 month = not available
I usually buy instruments from italian reseller Batterfly, they told me that there is not even a date for availability so it's useless to put it on listing (like every other seller).
How are their assistance & tech support? I'm in search of a reliable reseller for a SDS2000X+ purchase.
Notes:
1. You may want to wait for the HDOs to be available on Amazon. Usually, Rigol stuff gets on Amazon shortly after release.
2. You may want to evaluate the HDO1K before purchasing: it's acoustically noisy (the HDO4K has two 3600 rpm 60x15 fans.. Much probably the 1K has the same configuration).
Offline dschiedsch
  • Country: at
« Reply #451 on: November 07, 2022, 03:00:03 pm »
Hello
I was wondering if someone has thaught about replacing the fans in the scope
To me they sound relatively loud
The type is a
MGA6012MR-O15
If you have the space, you can fit a thicker, lower RPM fan in there. If the replacement fan has the same power rating, it moves about the same amount of air versus pressure so it should provide an equal amount of cooling.
Seems to be enough room in there.
I will look at thicker versions.
Also the 30dBA from the datasheet of that one seem much lower than what i hear
because that sure is not the rustling of leaves in the wind.
Offline balnazzar
« Reply #452 on: November 07, 2022, 03:24:14 pm »
Look for Noctua and Noiseblocker, 25mm thick.
Thinker fans move much more air per rotation.
Offline TK
« Reply #453 on: November 07, 2022, 04:21:31 pm »
I received the scope today... software seems to be very very unreliable.  When I enable SPI decoding, it hangs and restarts all the time.  It is the first test I run on new scopes and this one failed miserably.
I see a huge BUGS BONANZA video coming from Dave...
Fan is very noisy, scope UI in general is very responsive and I like the UI design, the screen size and brightness.
The following users thanked this post: thm_w, Martin72, hhappy1
Online 2N3055
  • Country: hr
« Reply #454 on: November 07, 2022, 04:34:05 pm »
Can you move and resize decode windows? What is shown in User Manual is very bad layout, pretty much unusable....
As for the bugs, I did say it all seems very rushed to the market..
Online Martin72
  • Testfield Technician
« Reply #455 on: November 07, 2022, 04:48:06 pm »
As seen as on the MSO5000...Let´s hope he got time for it.
Oh not again rigol...
5000/7000 bugs weren´t fixed all until today, I´ve got a bad feeling about the new ones...
Let´s hope I´m wrong.
(Kierkegaard)
Online Martin72
(Kierkegaard)
Offline tv84
  • Country: pt
« Reply #457 on: November 13, 2022, 02:06:27 pm »
Isn't this OT? Are we not posting on the wrong thread (at least according with the title)?  :-//
Online Martin72
« Reply #458 on: November 13, 2022, 02:11:47 pm »
 ;D
(Kierkegaard)
Offline dschiedsch
  • Country: at
« Reply #459 on: November 16, 2022, 01:36:24 pm »
Seems there is a first FW update available for the HDO4K
https://www.rigol.eu/En/Index/listView/catid/28/tp/6/cat/7/xl/52
no description though
The following users thanked this post: thm_w, Fungus
Offline skander36
« Reply #460 on: November 16, 2022, 11:15:25 pm »
In the FPGA section we can see BODE reference ... Maybe with an external gen?
Online Martin72
« Reply #461 on: November 17, 2022, 12:11:37 am »
Doesn´t looks like it was implemented with the actual firmware.
In case of the both HDO´s, it can go only this way.
Or this is meant for future models.
Or this is meaning nothing... :-\
(Kierkegaard)
Offline thm_w
  • Non-expert
« Reply #462 on: November 17, 2022, 12:58:21 am »
Translation:
- Complete chip and board level self-test, including DDR calibration parameter readback
- Conventional oscilloscope program, without Bode plot
- Bode function version, without high resolution
So for whatever reason, generating a Bode plot means no access to high-resolution. I wouldn't expect a bode plot to be very taxing, as its just plotting data, you can use the oscilloscopes built in measurements to do that.
Could be a code thing, they have a Bode plotter that works in 8-bit and they haven't ported it to 12-bit.
edit: missed that A75T and A100T, is that a different FPGA device?
« Last Edit: November 17, 2022, 01:01:03 am by thm_w »
Online 2N3055
  • Country: hr
« Reply #463 on: November 17, 2022, 09:57:38 am »
Nobody noticed a mention of HDO2000  ?  ^-^
Offline MegaVolt
  • Country: by
« Reply #464 on: November 17, 2022, 10:08:16 am »
Several FPGA bistreams mean that all the functionality does not fit at the same time. Those It is possible that a separate firmware is loaded for different modes.
Online Fungus
« Reply #465 on: November 17, 2022, 10:46:15 am »
There were a lot more models listed in the hacking thread, I thought you saw them...
https://www.eevblog.com/forum/testgear/hacking-the-hdo1khdo4k-rigol-12-bit-scope/msg4501234/#msg4501234
Online 2N3055
  • Country: hr
« Reply #466 on: November 17, 2022, 10:57:37 am »
Which is exactly what I said before..
While platform is generally united, every model still has some details that need be taken into account. FPGA bitstream is probably hardcoded for 1 or 2 ADC. Also if they make MSO those will have different FPGA bitstream too..
Online 2N3055
  • Country: hr
« Reply #467 on: November 17, 2022, 11:06:35 am »
Thank you for pointing that out, no I didn't. My mind immediately spotted 8000A as out of pattern, and since that was model much more interesting to me it got my attention.. It's not like I do this as a professional analysis where I pay complete attention to every detail... We are just discussing these things here for fun..
And since I noticed it now, I wonder what that one would be..
Originally HDO1000 datasheet was saying 1GS/s sampling rate. Then they changed it to 2GS/s.
Could it been that they meant to release 2000 but won't?. They realized there is too much segmentation on basically same hardware?
Or if they will release 2000 what would it be?
They cannot make 2000 sample faster than 1000 because that is 4000 already...
They say HD so it has to be 12 bit.
Maybe 1000 with MSO option will be called 2000?
 :popcorn:
Offline skander36
« Reply #468 on: November 17, 2022, 04:01:48 pm »
The apk's launch in emulator but because they don't found the specific hardware, freeze on the Rigol logo screen.
Offline dschiedsch
  • Country: at
« Reply #469 on: November 18, 2022, 09:12:39 am »
Did a little comparison between old and new FW
Seems like there is a new/different HW revision out there
They included a new network driver
"insmod ethernet PHY driver for Motorcomm - YT8531S"
also the bitstream files for the fpga include a B Version now with a note suggesting a different FPGA (probably less Tile fabrics)
The main apk as well as the launcher and Webcontrol got an update
as did the bitstream files for the FPGA
Haven't found an official change log yet though
The following users thanked this post: thm_w, RobbiTobi
Offline thm_w
  • Non-expert
« Reply #470 on: November 18, 2022, 10:36:03 pm »
Yeah, so the two part numbers are (datasheet, table):
- XC7A75T 75520 LE, 180 DSP, 3780 RAM
- XC7A100T 101440 LE, 240 DSP, 4860 RAM
Cost is about 17% more, on Digikey.
Online Fungus
« Reply #471 on: November 19, 2022, 05:48:08 am »
Maybe they've optimized the code so they don't need the more expensive FPGA any more.
Online 2N3055
  • Country: hr
« Reply #472 on: November 19, 2022, 07:42:33 am »
Something like that, yes.
I explained it before. Because production is just ramping up and development is obviously not finished yet, so they repurposed some HDO4000 BOM, until they make sure how much they can cut down. Then they will make "optimized" (cut down) version. But they actually have to develop it to the point that they have good idea of resources they need.
That is not uncommon during development. But it normally happens during development. Meaning these scopes were released during late prototype phases. Basically when they had release candidates they released product. That is slightly pre beta or early beta phases... A bit too soon for my taste.
That explains state of software.
Offline markone
« Reply #473 on: November 19, 2022, 01:11:01 pm »
I would not be surprised if XILINX's FPGA above some size are in embargo (if aimed to CHINA) due to current international situation.
Offline markone
« Reply #474 on: November 19, 2022, 01:27:05 pm »
I contacted Rigolshop.eu regarding availability of HDO1072 / HDO1074, i was told that this models will be in stock after mid-December.
In the meanwhile i can spot the very same SKUs fully available on rigolna.com ... WT* is that ?!
As if European money is not welcome in Rigol's pockets, not happy at all about that.
All this while the euro is at all-time low exchange rate vs USD.
Just out of curiosity, how much are purchase fee in USA for this kind of products ?
Here in Italy we have a stunning 22%  ::)
