Hello,
Maybe we can make a noise comparison between Rigol and Siglent 12 bit scope.
I got a 12bit siglent...
They were several settings mentioned on the side before, which settings should I use for compare?
Hallo,
If I remember correctly, you have the SDS2104X HD.
We just have to consider the difference in bandwidth when assessing it.
(According to tautech's hint, perhaps 200 MHz bandwidth would also be possible?)
Maybe you should not use the first channel, because with my RTA4000 the display there also disturbs something.
All 8 measurements with 200 MSa memory and 2 GSa/s sampling rate
1 mV/div 50 Ohm maximum bandwidth (100 MHz or 200 MHz)
1 mV/div 50 Ohm 20 MHz bandwidth
1 mV/div 1 MOhm maximum bandwidth (100 MHz or 200 MHz) open input (deepl say open entrance)
1 mV/div 1 MOhm 20 MHz bandwidth open input
1 V/div 50 Ohm maximum bandwidth (100 MHz or 200 MHz)
1 V/div 50 Ohm 20 MHz bandwidth
1 V/div 1 MOhm maximum bandwidth (100 MHz or 200 MHz) open input
1 V/div 1 MOhm 20 MHz bandwidth open input
Thanks in advance.
Best regards
egonotto
