In the past, I've done some testing with the MSO5000, which still has the dots mode. In certain configurations, dot mode looks very clear and nice. But if you go to zoom in further, it starts to interpolate and put intermediate points using sinx/x interpolation. Siglent is more predictive, like "in the book".
I've come to terms with the fact that it's noisy and I don't use it below 20mV/div. I put it down to the fact that the input amplifier runs at high temperature and could be an explanation. It was the first oscilloscope I came across that had heat sinks on the input stages. Not very usual for me.
To get to 8GSa/s at a decent price I suspected that there were actually several DACs running in interleaved mode in the DAC chip. It could be for example 8x1GSa/s or even 16x500MSa/s combined in pairs of 2 and 4 respectively to cover the 4 channels. That would explain why it behaves so strangely in dots mode and why it doesn't have X interpolation mode. It's hard to align all these DAC's, so the software has to do something about it.
In this way I thought Rigol managed to get such a good price for the MSO5000.
The DHO also has the input stage operating at high temperature, but at the same time has low noise. I seem to be missing something here. Also the DAC they manufacture may be hiding some unknowns.
My main field of work is in power electronics, so I don't have expertise in high frequencies small signals. It's quite possible I'm wrong in the above
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
