Well, I've received ANOTHER of these, and this unit actually does something! When it powers up, it beeps, shows "POWER UP SELFTEST" and beeps again and nothing!
However, I was able to figure that there was an UART running on one of the unpopulated headers. Have a look at the attached picture. J101 has 3v3 on its pin#1, TX, RX and GND on the other ones.
Here's the dump, and sorry for it being so crappy (last week was fine, but this week I get garbled text all over the place, and looking on the logic analyzer, I see high frequency noise on some characters, causing them to corrupt):
*******Beginning8System<Initialization*******
CPU ID = A0 PXA255
SDcLK[1]<>>= MemClk
MemClk = 99.53 MHz
Run Mode = 28*<Memclk\x8A\x8D8 Turbo Mode = Run Mode
Mode: RUN
Beginning SDRAM Scrur...\x8A\xCDSDRAM Scrub Complete
\t SDRAM SUCCESSFULLY TESTED
\x8D
Microsoft Windows CE Ethernet Bootloader8Common<Library Version 1.0 Built Nov 19 2008 11:52:54
Microsoft Windows CE8Etlernev<bootloader 3.3 for the TS/TV90 PXA255 Platform (Built Nov 19 2008)
EbOOVLcDInt
ERROR:: OEMReadACQByte returns as no data \xFF .
8-cleqrFrameBuffer
Blcommon - System ready!
Preparing for download...
jum|ing>to8the image directly
Blcommon - ROMHDR at Address 00000044h
OEMLauncl\xCD\x8AOEMNyunch: Before Fash Read
OEMLaunch
Windows CE Kernel for ARM (Thumb Enabled) Built<on<Mqr813 2003 at 22:52:56
ProcessorType=02d0 Revision=6
sp_abt=ffff5008<s|_irq=ffff2800 sp_undef=ffffc800 OEMAddressTable = 800ba20c
Sp=ffffc7cc
FMD_Init: SUCCESS\x8D\x8AFMd_Init: Reading Flash memory location from Registry 0x610ec
INFO: FMD_Init:<Flqsh Address=0xb9300000 Length=0xa00000.
DAG_MANAGER DLL_PROCESS_ATTACH entered
+DAG_Init\x8D\x8A+Diqgnostic managerInitialiseAddress
Diagnostic manager Successfully<iniviqlized
Build test IOCTL DIaGNOSTIcS<MANAGER
...Waiting for Keypad Interrupt IN KeypadIntrThread...
RasEntry8'|USb'<created
RegistryEntry '`USB' Created.
CTS90App::InitInstance
DIRECTORY xrofiles<\x8D\x8ADIRECTORY My Documents
DIRECTORY Program Files
DIRECTORY Temp
\x8ADIREcVORY Windows
TS90 board
TS90_SPA.DLL LOADED
POWER BUTTON Interrupt Service Routine
The last line is printed ONLY when I hit the power button again; in which case, consumption drops to about 30mA (where as it was hovering 130mA beforehand). Nothing gets spewed besides that, nothing I send gets received, absolutely any interaction.
HOWEVER, and feeling that this is a lost cause, I analyzed the pinout of the LCD, because it's a big one and looks cool. Since this unit "does something", I just probed with a voltmeter to figure out the pinout. I come to the conclusion that it must be something like this:
* logic signal 0
* logic signal 1
* logic signal 2
* logic signal 3
* -15v
* 5v
* gnd
* -15v
* logic signal 4
* logic signal 5
* logic signal 6
* logic signal 7
Jumping to my saleae clone, I've got the following capture (attached).
Seems like the last four signals are the pixel data, whereas the first 4 are syncs and clocks.
Being somewhat familiar with these signals, I figured the fast one is the pixel clock, the intermediate one is the HSYNC and the slow one is VSYNC. By counting pulses, I gathered it's 200 lines by 640 (because the 4 pixel data are arranged on 4 columns of the display on each clock pulse, and there were 160 clock pulses in between 2 HSYNC pulses; 160*4=640).
Attached is the pinout I figured out.
By that, I found a compatible LCD module from Kyocera: "DMF-50036ZNBU-FW-BAN" (which I also attached).
I'll be using that LCD with an esp32 (with the I2S in "LCD" mode) for some other stuff, until I can figure out how to fix this board
