Yes, spectrogram is in an option called interference analysis, FPH-K15
also i would recommend the preamplifier option FPH-B22
What is your intended purpose with the FPH? general faultfinding measurements or interference hunting?
I use for the latter and it's hard to beat for that purpose, in that case you might want to add the options K7 modulation analysis and K43 receiver mode.
