Hello all,
@ H.O
Sorry my friend, my scope is in its 30 days trial period. I already found some things that I am hating about it: for example, the multipurpose rotary encoder sensitivity that is pure garbage. On some menus it just jumps around, while on others it's usable-ish...
That said, I won't open the scope until I set up my mind about keeping it or sending it back to the vendor.
@jjoonathan
If I decide to keep the scope, I'll surely rip off the label. I mean, if it passes my early-mortality tests, I believe it won't fail during normal usage and then I won't need the waranty.
Meanwhile, where can I find the 500 MHz code? I've looked for it, but didn't find it (it could be my eyes or my keywords). Can you point me a direction? Thank you.
Best regards,
Emmanuel.
