Hallo every one
I was repairing an analyzer recently.The fault phenomenon is that the pressure deviation exceeds the allowable value.
I read the user manual and found only instructions for oxygen calibration,There is no detailed calibration procedure for pressure sensors or flow sensors.
By reading "User Communication Interface" I found some clues about calibration,The calibration date and calibration ID are marked on it.
In the normal user interface, I do not see the calibration date and calibration ID.
So I got the GUI firmware and read it with "Winhex" software,Found some information about calibration, but it is still incomplete.
Due to language differences, I am not sensitive to English characters.
If you can find some clues, I look forward to your help, thanks
