Author Topic: IT8512(A+) or the M9812 ?  (Read 12507 times)
Offline cj0
Re: IT8512(A+) or the M9812 ?
« Reply #25 on: November 28, 2018, 03:10:41 pm »
Itech publishes an SCPI programming manual for 85xx models: IT8511+/IT8511A+/IT8512+/IT8512A+/ IT8512B+/IT8512C+/IT8512H+/IT8513A+/ IT8513B+/IT8513C+/IT8514C+/IT8514B+/ IT8516C+. The first revision of that manual is dated: May 4th, 2018.
My IT8512A+ from January 2015 running firmware 1.12 doesn't seem to understand SCPI commands.
Does anyone have experience or a clue since which firmware version the IT8512(A+) e-load is having SCPI support? And whether firmware is (user) upgradable?
PS Itech did a rush job on that SCPI for 85xx manual, the PDF still includes "it8800" as title in the meta data.
« Last Edit: November 28, 2018, 03:13:55 pm by cj0 »
Offline onesixrightTopic starter
« Reply #26 on: November 28, 2018, 10:29:49 pm »
I have the same unit, also v1.12. Would be nice if it understands SCPI, the windows software is crap :palm:
Batronix sells it now: https://www.batronix.com/shop/load/ITECH-IT8512A+.html
In their manual they write about SCPI, https://www.batronix.com/files/ITECH/IT8500+/IT8500+_manual_en.pdf.
Apparently you should be able to select it via System menu, in there should be a protocol option, which is named after the RS232. But I don't see that.
They don't mention any firmware updates.
