Author Topic: Rigol DS2000 Hardware version 2.0  (Read 46301 times)
Offline Carrington
Re: Rigol DS2000 Hardware version 2.0
« Reply #25 on: August 05, 2013, 11:50:25 am »
Hi Carrington, moving the trigger between 500 to 600 and I get very much the same results of my pic2.
Ok, thank.
Anyone else have a similar result?  :-//
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline PA0PBZTopic starter
« Reply #26 on: August 05, 2013, 01:33:24 pm »
My result for (1) is the same, just a little bit less amplitude.
For (2) I can't set the trigger higher than 400uV otherwise it does not trigger. When measuring the top cursor is at 600uV, the bottom one at -700uV so total 1.3mV
Offline Carrington
« Reply #27 on: August 05, 2013, 01:39:26 pm »
Hi PA0PBZ, thank.  :)
Curious! Then yours (H.W. ver. 2.0) has a little less noise.
« Last Edit: August 05, 2013, 01:46:08 pm by Carrington »
Space Weather.
Offline Mr Simpleton
  • Not the sharpest knife in the drawer
« Reply #28 on: August 05, 2013, 01:55:04 pm »
Took delivery of a DS2072 today...
Must have been NOS (new old stock) as it has H/W rev1 produced in week 20.
Pity I did not see this thread when ordering...
As for noisefloor, loooks pretty much what all the other have :D
« Last Edit: August 05, 2013, 04:58:47 pm by Mr Simpleton »
Offline Carrington
« Reply #29 on: August 05, 2013, 05:11:22 pm »
Thanks Mr Simpleton, this results seem to be very similar to mine.
Anyone with HW version 2.0 please make this "test".
« Last Edit: August 05, 2013, 05:14:50 pm by Carrington »
Space Weather.
« Reply #30 on: August 05, 2013, 08:44:15 pm »
My Pictures  :)
(1) Is now the same as the others, (2) shows a bit less noise and the trigger is set to 500uV, it triggers about once every second. Above 500uV it does not trigger at all.
« Reply #31 on: August 05, 2013, 08:51:51 pm »
Still fooling around with the 50 Ohm option, found this SCPI in the firmware:
.RES.DATA....CHANnel.CHAN....BWLimi
t.BWL.BWLimit?....BWL?....COUPling.
...COUP....COUPling?...COUP?...IMPe
dance...IMP.IMPedance?..IMP?....SCA
:CHAN1:IMP? returns 0MEG, and I have not found a way to change it via SCPI, tried several variations of CHAN1:IMP 50... but nothing.
Offline tinhead
« Reply #32 on: August 05, 2013, 08:59:25 pm »
try CHAN1:IMP FIFTY
« Reply #33 on: August 05, 2013, 09:01:39 pm »
try CHAN1:IMP FIFTY
I will as soon as I hook it up again, but the return value of 0MEG doesn't give much hope anyway.
Offline tinhead
« Reply #34 on: August 05, 2013, 09:08:32 pm »
try CHAN1:IMP FIFTY
it is "OMEG", not "0MEG" and it is exactly what the firmware have to return. The "FIFTY" is another one possible value in the firmware.
« Reply #35 on: August 05, 2013, 09:41:17 pm »
Yes, it is 0MEG, but if it was a working command it should have returned 1MEG isn't it?
Offline tinhead
« Reply #36 on: August 05, 2013, 10:13:18 pm »
it will return what has been coded into the firmware, and when you look inside you will find "OMEG" and "FIFTY".
The "O" in "OMEG" menas nothing else than "one", so everything fine. Sure, 1MEG could be good as well, but the number "1" in string is probably what they tried to avoid.
« Reply #37 on: August 05, 2013, 10:20:31 pm »
Yeah, I found it too. Thanks for the suggestion and I will try it and let you know.
Offline Carrington
« Reply #38 on: August 05, 2013, 11:20:52 pm »
My Pictures  :)
Thanks, as we see all the results are very similar, but you have forced the trigger a little true?
Well, no matter.
Space Weather.
Offline Carrington
« Reply #39 on: August 05, 2013, 11:29:50 pm »
Do you use a Hex viewer to see directly inside the gel file? Snoopers, LOL...
Do you have a idea of where is keep the serial number? And how change it?
Space Weather.
Offline true
  • INTERNET
« Reply #40 on: August 06, 2013, 12:30:02 am »
can use strings, or an editor yes
I would like to work on this, but nobody seems interested in doing a JTAG dump of fw nor helping me get some working binaries of the blackfin IDA parts (cybernet likely has them, I can't compile them by instruction, the closest I got was with VS2008 but the resulting binaries didn't work). There may be a menu or config file to set this but without being able to work with the fw, I can't do shit.
Offline Carrington
« Reply #41 on: August 06, 2013, 12:44:07 am »
Not stored in the FRAM?
I can't do the dump via JTAG, becasue I don't have the equipment for do it.  ???
Space Weather.
Offline true
  • INTERNET
« Reply #42 on: August 06, 2013, 04:34:20 am »
No; probably in the NAND.
Figuring out anything else hidden needs a good dump
Offline bluesmoke
« Reply #43 on: August 06, 2013, 07:09:00 am »
Then serial must be in nand. Studio25 wrote 0's and ff to the fram and it didn't change the serial.
Unfortunately I don't have the tools to do a jtag dump either. I would love to get my serial back too!
Offline Carrington
« Reply #44 on: August 06, 2013, 04:43:17 pm »
This is very interesting, it reminds me to the "jumpers" of the DS4000, but it is less obvious.
« Last Edit: August 06, 2013, 04:45:19 pm by Carrington »
Space Weather.
Offline Carrington
« Reply #45 on: August 06, 2013, 05:12:17 pm »
DS2000 Memory.
Space Weather.
« Reply #46 on: August 06, 2013, 05:19:45 pm »
I browsed my pictures and found a little bit better one, you can see clearly that it is 2 rows and the jumpers are smd (resistors?)
Offline Carrington
« Reply #47 on: August 06, 2013, 05:27:01 pm »
Ha ha, they are not in the same position. What the hell change this?  :-//
Space Weather.
« Reply #48 on: August 06, 2013, 05:29:58 pm »
That's the whole idea behind jumpers isn't it?  :P
Offline Carrington
« Reply #49 on: August 06, 2013, 05:33:11 pm »
"Elementary My Dear Watson"  ;D
No one has noticed this before?
Have more pictures from other DS2000s would be nice.  ;)
« Last Edit: August 06, 2013, 05:51:21 pm by Carrington »
Space Weather.
