Hi everyone. I am new on the forum.
Some questions for owners of the Rigol DS1104Z. I have ordered a DS1104Z-Plus-
S. But the one I received is labeled "DS1104Z-Plus" (without the S i.e. source channels / function generator option):
1. System utility : displays "DS1104Z Plus" . Should not it display "DS1104Z S Plus" ?
2. It is written on the front panel (right to the blue rigol logo)
Should not it read "DS1104 Z Plus
S on that front panel ?
3. I do not see "Function generator" in the list of installed options
However, the scope I received
does have the function generator (2 sources BNC in the back) and it seems to work. I tested with BNC cables from the source1&2 to the inputs.
I am pondering whether to return the unit but I feel this is going to be a waste of time as it seems I have all the functions. Are there any other diffferences between those 2 models I should know about ? I looked at the datasheet and rigol shop and I do not see much else.
I filed a case with Amazon & rigol but I would like an opinion from the forum as well.
regards,
Good day.
