Author Topic: RIGOL DS1102Z-E  (Read 61403 times)
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #25 on: December 29, 2020, 12:14:17 pm »
Hi there,
does anyone have a new experiences with DS1102Z-E?
Maybe to unlock 200mhz band?
From what I can see it is a scope already unlocked to 100Mhz.
It is not possible to turn it into a 200Mhz scope.
There's a matching 1202X-E model so no reason why the 1102X-E shouldn't be unlockable.
https://shop.rigol.eu/Oscilloscopes/ds1000z-e
So there is. Has that been released recently, like the last three months?
When I got mine I did a check and I did not find a 200Mhz version. Now I wonder whether I missed it or was released in the meantime.
EDIT: Nope, looks like it has been around for a year
« Last Edit: December 29, 2020, 12:18:15 pm by Microdoser »
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #26 on: December 29, 2020, 03:51:10 pm »
Hi there,
Does it mean 1102Z-E can be unlocked to 200MHZ? I unlocked by using a key provided on this site http://gotroot.ca/rigol/riglol/ and unfortunate bandwidth still is at 100MHz
Online Fungus
Re: RIGOL DS1102Z-E
« Reply #27 on: December 29, 2020, 04:01:49 pm »
Probably, but nobody here knows the code to use yet.
There's no "200MHz" option on there.  :-//
There's probably a combination of letters that will do it. Somebody needs to download the source code for Riglol and play with it, figure out what they are.
The following users thanked this post: caheo
Offline Dlrowdna
  • Country: ru
Re: RIGOL DS1102Z-E
« Reply #28 on: January 10, 2021, 07:33:44 pm »
I hope no one ordered the encoder from my link? It doesn't work. It jumps over one menu option. I discovrred this only after it came to me. Sorry.
Looking for a suitable type.
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #29 on: January 11, 2021, 01:19:31 pm »
If that is possible, it should be very easy to find out. One just have to play with the bits (using the letter combination is harder to find it).
Does this scope have any licensable option?
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #30 on: January 11, 2021, 01:29:27 pm »
It's unlocked by default. What do you mean by saying licensable? Any tutorial on how to check bits in the firmware? Thanks!
Online Fungus
Re: RIGOL DS1102Z-E
« Reply #31 on: January 11, 2021, 01:37:35 pm »
Note that Bandwidth is listed in the "options".
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #32 on: January 11, 2021, 03:05:30 pm »
I'm getting old for this...  :palm:
Try DSF9 and report the outcome.
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #33 on: January 11, 2021, 05:11:02 pm »
I am not sure if I am doing correctly but this is what I tried but unsuccessful. Enter keys and it said Options successfully installed but Bandwidth is still 100M
« Last Edit: January 11, 2021, 05:12:45 pm by caheo »
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #34 on: January 11, 2021, 05:15:48 pm »
I remember having a go when I first got mine, the only thing I could find to activate that wasn't already unlocked was the 500uV range which I was advised was 'buggy' so I reverted back to vanilla.
Still, interested to see if anything comes from this. I'm rooting for you.
« Last Edit: January 11, 2021, 10:46:40 pm by Microdoser »
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #35 on: January 11, 2021, 05:21:35 pm »
You're doing ok. No need to specify the privkey.
Show us a printscreen of the option screen after that DSF9.
I also attached version screenshot as well. Thanks!
Online Fungus
Re: RIGOL DS1102Z-E
« Reply #36 on: January 11, 2021, 05:49:46 pm »
What's "DG"???  :o
Online Fungus
Re: RIGOL DS1102Z-E
« Reply #37 on: January 11, 2021, 06:50:10 pm »
I think it was activated by the DSF9, right? Digital Generator...
Yes, it appeared after DSF9 but I don't know what it is.
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #38 on: January 12, 2021, 10:23:16 am »
@caheo,
Now, try DSJR.
What's "DG"???  :o
Thanks tv84! It is what happened now. I got two bandwidths 100M+70M, is that for 4 channels? :D
DSF9 activated DG, I am not sure what it means!
« Last Edit: January 12, 2021, 10:28:36 am by caheo »
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #39 on: January 12, 2021, 11:00:24 am »
Try DSCA.
Same options installed. Do I need to uninstall code first? When I tried to telnet to port 5555, there is no reply back!
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #40 on: January 12, 2021, 11:09:04 am »
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #41 on: January 12, 2021, 11:13:34 am »
DSAB - 00011 10000 00000 00001 - Advanced Triggers
DSAC - 00011 10000 00000 00010 - Decoders
DSAE - 00011 10000 00000 00100 - 24M Memory
DSAJ - 00011 10000 00000 01000 - Recorder
DSAS - 00011 10000 00000 10000 - DG
DSBA - 00011 10000 00001 00000 - 500uV Vertical
DSCA - 00011 10000 00010 00000 - Power Analysis
DSEA - 00011 10000 00100 00000 - 100MHz
DSJA - 00011 10000 01000 00000 - 70MHz
DSSA - 00011 10000 10000 00000  (invalid)
DTAA - 00011 10001 00000 00000  (invalid)
DUAA - 00011 10010 00000 00000  (invalid)
DWAA - 00011 10100 00000 00000  (invalid)
D2AA - 00011 11000 00000 00000  (invalid)
Suggestions?
« Last Edit: January 12, 2021, 12:20:11 pm by tv84 »
Online Fungus
Re: RIGOL DS1102Z-E
« Reply #42 on: January 12, 2021, 11:26:35 am »
Try DSCA.
DSCA - 00011 10000 00010 00000 - ??
DSSA - 00011 10000 10000 00000  (invalid)[/font][/b]
Suggestions?
Maybe need to remove the 100MHz and 70MHz options before using DSCA.
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #43 on: January 12, 2021, 11:32:17 am »
Try DTAA - 00011 10001 00000 00000
DTAA - invalid license
DSFR - all options
DSCA- Power Ana. (Power Analyst???)
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #44 on: January 12, 2021, 11:34:01 am »
Try DSCA.
Suggestions?
DSCA Power Ana.
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #45 on: January 12, 2021, 11:56:24 am »
What about DSNA - 00011 10000 01100 00000
DSNA 100M + 70M
DSJA 70M
DSEA 100M
« Last Edit: January 12, 2021, 12:00:41 pm by caheo »
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #46 on: January 12, 2021, 12:02:17 pm »
Try:
DUAA   00011 10010 00000 00000
DWAA   00011 10100 00000 00000
D2AA   00011 11000 00000 00000
If these don't work, I suggest doing what Fungus suggested: remove all and start from left to right (countdown up to the 70 MHz option).
« Last Edit: January 12, 2021, 12:14:58 pm by tv84 »
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #47 on: January 12, 2021, 12:16:55 pm »
Try:
DUAA Invalid
DWAA Invalid
D2AA Invalid
I manually scanned these parameter and DSAA doesn't give any invalid or success signal (no beep as well, strange)
DSDA 500uv + Power Ana.
DSFA 500uv + BW 100M
DSPA 500uv + BW 100M + BW 70M
I did, :SYSTem:OPTion:UNINSTall and then :SYSTem:OPTion:INSTall for each case
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #48 on: January 12, 2021, 12:22:57 pm »
Desperate attempts:
HSAA
PSAA
Online tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #49 on: January 12, 2021, 12:25:24 pm »
DSAA - 00011 10000 00000 00000
This is the <NULL> option... :)
