Author Topic: RIGOL DS1102Z-E  (Read 60026 times)
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #50 on: January 12, 2021, 12:29:03 pm »
Desperate attempts:
HSAA
PSAA
haha, both of them are NULL
Offline tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #51 on: January 12, 2021, 12:30:25 pm »
So, I would conclude that 200MHz is not an option.  It's like failure...   :-DD
The following users thanked this post: caheo
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #52 on: January 12, 2021, 12:45:09 pm »
I think so as well... sadly
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #53 on: January 12, 2021, 02:59:05 pm »
I find it very hard to believe. The only way to be sure would be to open up one of each and look at the components.
Offline tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #54 on: January 12, 2021, 09:26:28 pm »
Maybe a memdump from a DS1202Z-E is sufficient...
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #55 on: January 13, 2021, 01:23:29 am »
Is there a chance which I need to change my device to DS1202Z-E model to make it work???
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #56 on: January 13, 2021, 11:27:26 am »
After doing my own attempts I became certain it was not possible to get 200Mhz out of a 1102Z-E. I have watched with interest and hope but I still remain certain that it is not possible with this scope.
If anyone does a teardown of both or knows where teardowns of both might be, I would be very interested in seeing them but I suspect there will be vital differences.
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #57 on: January 14, 2021, 12:53:34 pm »
Another way to test this would be for a 200MHz model owner to try to downgrade theirs.   >:D
Offline tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #58 on: January 14, 2021, 09:11:35 pm »
@caheo,
Test these options and report:
ASA9
BSA9
CSA9
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #59 on: January 16, 2021, 11:24:56 am »
@caheo,
ASA9
BSA9
CSA9
ASA9 Invalid license
BSA9 Invalid license
CSA9 Invalid license
RS39 Invalid license
The following users thanked this post: tv84, HHG
Offline calli
  • 3D Blender and Maker
    • Blender Buch
Re: RIGOL DS1102Z-E
« Reply #60 on: January 26, 2021, 05:20:29 pm »
just got my 1102Z-E.
What I mentioned is that there are LEDs under the plastic below the CH1 CH2 buttons, they light up shortly during boot.
I wonder: Is the DG (Function gen?) usable when set free?
And what is the Power Analysator?
Oh Edit/BTW: Is there a newer Firmware version than my 00.06.02?
BTW2: I find the Multipurpose Knob very sensitive... Often changing the selection during enter/press
Best,
Carsten
« Last Edit: January 26, 2021, 05:23:40 pm by calli »
Carsten Wartmann: Make Magazin DE - Autor - Dozent - 3D - Grafik - Maker
http://blenderbuch.de/
Offline caheo
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #61 on: January 28, 2021, 12:28:51 am »
I noticed these leds as well
Not what I am aware of
It's true and I think it's just normal for me :D
Best,
Carsten
The following users thanked this post: calli
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #62 on: January 28, 2021, 01:16:55 pm »
I also see those four LED lights on boot. These match the position of four buttons on a DS1104Z which suggests they share common circuitry behind the front panel.
This raises the question:
Can a DS1104Z be hacked to 200MHz?
Offline calli
    • Blender Buch
Re: RIGOL DS1102Z-E
« Reply #63 on: January 28, 2021, 01:19:53 pm »
I still wonder if I can use a code to have a function gen? Or ist the 1102 just lacking the HW?
And whats the Power Analyser OPtion?
Best,
Carsten
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #64 on: January 28, 2021, 01:36:15 pm »
Function gen needs more chips on the PCB.
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #65 on: January 28, 2021, 01:38:40 pm »
Yep. The PSB with the buttons will be common to all models.
No.
(and you wouldn't want a 4-channel, 200Mhz 'scope with only 1GS/sec, it breaks Fourier theory).
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #66 on: January 28, 2021, 06:04:04 pm »
No.
Then IMO a sharing of some internals lends credence to the idea that the DS1102Z-E can't be hacked to 200MHz. It seems more likely the DS1102Z-E is a stripped down version of the DS1104Z than a stripped down version of a 200MHz capable scope.
« Last Edit: January 29, 2021, 01:06:44 pm by Microdoser »
Offline tv84
  • Country: pt
Re: RIGOL DS1102Z-E
« Reply #67 on: January 28, 2021, 06:19:58 pm »
But, then what is a DS1202Z-E ?
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #68 on: January 28, 2021, 06:22:29 pm »
You can do 200Mhz when you only have two channels - 1Gsample/sec divided by two doesn't break Fourier.
Offline Microdoser
Re: RIGOL DS1102Z-E
« Reply #69 on: January 29, 2021, 01:07:53 pm »
Fair point. So the thing to check, for pointers on unlocking a DS1102Z-E, is how to limit a DS1202Z-E to 100MHz and then unlock that back to 200MHz.
« Last Edit: January 29, 2021, 01:09:58 pm by Microdoser »
The following users thanked this post: tv84, Fungus
Offline nightfire
Re: RIGOL DS1102Z-E
« Reply #70 on: February 07, 2021, 03:37:50 pm »
As I noted the DS1102Z-e being available on german amazon, I wondered if anyone could share some experience in daily handling.
My use would be a beginner to a DSO to get additional coverage of routine measurements, like jitter on some USB Power supplies etc. - and on my bucket list for the future I still have the item: Measurement of the burning time of a photographic flash by converting the light with a photodiode and measure that with an oscilloscope...
(Flash duration is about between 1/10000 sec and 1/100 sec for slower studio flashheads, meaning some duration betwwen 10 ms and 0,1ms)
For the price of about 260 € for Prime members including shipping, I cannot complain, and if I really would feel the need for a better scope, I would know what I have to buy and won't have much loss of value by selling it after a short time...
Opinions?
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #71 on: February 07, 2021, 04:17:31 pm »
Opinions?
Timing of pulses can be done to about 4 nanosecond resolution. It will definitely be able to do those things.
Handling? It's just a DS1054Z but with less channels. There's a lot of information about the DS1054Z online.
« Last Edit: February 07, 2021, 04:27:38 pm by Fungus »
Offline Frank Barella
Re: RIGOL DS1102Z-E
« Reply #72 on: February 08, 2021, 10:25:26 am »
Hello maseryoda. Could you please tell me where did you find the DS1102Z-E at 215€??I think it's a very good price, Thanks!
Offline square74
Re: RIGOL DS1102Z-E
« Reply #73 on: February 19, 2021, 11:08:57 am »
same question for me.
Scope is on Rigol-Shop EU, but only with payment creditcard.
https://shop.rigol.eu/product-digital-oscilloscope-ds1102z-e
I would like to buy one, but with paypal or Klarna.
Would like to know, where to buy, maybe in Europe.
Thanks.
Offline nightfire
Re: RIGOL DS1102Z-E
« Reply #74 on: February 19, 2021, 10:08:28 pm »
I got mine this week from Amazon Germany- as Prime Customer the price difference is not much different considering Rigol EU charges some additional €€€ for shipping.
