Author Topic: RIGOL DS1102Z-E  (Read 60028 times)
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #175 on: April 04, 2023, 04:24:07 pm »
Take a short video.  I have the same behavior in all three modes.
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #176 on: March 17, 2024, 04:59:11 pm »
Hello,
I own a brand new DS1102Z-E since a few weeks and tried to replace this horrible, non-indexed multipurpose encoder. I found the Bourns PEC11R-4215F-S0024 (24 positions) but with this encoder the Scope always triggers the menu twice, so it jumps over one menu item :palm:.
Any other suggestions for the correct encoder?
Presumably you want the one with less pulses:  Bourns PEC11R-4215F-S0012
https://www.bourns.com/docs/product-datasheets/pec11r.pdf
Hello.  I tried replacing the native encoder with another one with 12 clicks and 12 pulses.  If you do not rotate quickly, the menu bar jumps two positions.  Do I understand correctly that for correct operation me will need an encoder with a number of pulses that will be half as many clicks?
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #177 on: April 28, 2024, 07:29:54 pm »
As a result, I installed this encoder from the link below.  Fits very well.  Both in height and in work.
https://aliexpress.ru/item/4000914884857.html
