Author Topic: RIGOL DS1102Z-E  (Read 60032 times)
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #125 on: November 17, 2022, 04:04:44 am »
I freeze the trace and the trigger displays WAIT..
When I change the time base to 5ns, the brightness decreases!!! :(
so our actions were different
As for versions, I'll duplicate:
go to "storage" there select CSV or Param and save the file. Then open the saved txt and in the first paragraph it is written about the device parameters
but i'm pretty sure all the specs will be the same
« Last Edit: November 17, 2022, 04:07:03 am by trmntr »
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #126 on: November 17, 2022, 05:41:08 pm »
Thank you trmntr
Yes, all parameters are the same
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #127 on: November 20, 2022, 03:11:29 pm »
Has anyone tested the operation of an external trigger?
There are cases when it turns out this does not work on the device
« Last Edit: November 20, 2022, 03:15:32 pm by trmntr »
Offline Piton
  • Country: ua
Re: RIGOL DS1102Z-E
« Reply #128 on: November 20, 2022, 07:50:08 pm »
It's like that for everyone. It is necessary to reset to the factory settings: if you have not forgotten, then the 5th button on the top on the left side, you must hold it when you turn it on. After downloading, there will be a menu in Chinese.
Offline phamthai2503
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #129 on: November 21, 2022, 03:51:09 am »
Hello, I currently want to buy an oscilloscope to serve my laptop repair needs. There is 1 store in my country selling Rigol DS1102Z-E (100% New) $280  , and there are 2 more options of Second-hand goods (95%) Rigol DS1102E (100Mhz) $200  + Rigol DS1152E (150Mhz) $208
Which should I buy? please advise me! Thank you
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #130 on: November 21, 2022, 06:21:23 am »
DS1102Z-E
The following users thanked this post: phamthai2503
Offline Prizmatic
Re: RIGOL DS1102Z-E
« Reply #131 on: November 21, 2022, 04:22:19 pm »
Got mine 2 weeks ago. I bought it knowing about the 5ns timebase issue, TBH its not as bad as I expected. I only need 2 channels and for the price I think its a very good scope for hobby use. Fan noise is a bit higher than I'd like, my only real grumble.
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #132 on: November 21, 2022, 11:10:08 pm »
DS1x02Z-E owners, do the following manipulation:
- apply a sinusoidal signal (or other) of 10MHz or 20MHz on both channels
- set the memory depth to 6kpts
- set the time base to 10ns
And tell me what you think about the display of traces on the screen.
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #133 on: November 22, 2022, 05:52:50 am »
PatrickВ, show us a screenshot of your
Offline Fungus
Re: RIGOL DS1102Z-E
« Reply #134 on: November 22, 2022, 06:00:20 am »
Can you post screenshots so people who don't own one can see the problem, too?
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #135 on: November 22, 2022, 07:53:02 am »
Watch the videos on https://www.dropbox.com/scl/fo/9els7w9e8dfxifkrp9bcj/h?dl=0&rlkey=t6g6y4lli5cviuu50as7yxx2n
With the first video, you will see with which scope settings (10ns, 6kpts and 10MHz signal on both channels), the flickering of the traces appears or not.
In the second, you will see that this problem is visible with certain signal frequencies on the 2 channels.
Of course if the brightness is at 100%, you may not see this bug but it exists nevertheless.
The following users thanked this post: Microdoser, phamthai2503
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #136 on: November 23, 2022, 07:00:26 pm »
Have you noticed the same faults on your RIGOL DS1000Z-E oscilloscopes?
Of course if you have 100% brightness, you won't see them.
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #137 on: November 26, 2022, 07:30:50 am »
One of the users of the monitor.net.ru resource replied that he had not noticed such an anomaly.
I can’t check myself, there is no signal generator.
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #138 on: November 26, 2022, 07:56:54 pm »
I don't think this is a problem just with my scope.
But that's what I want to check this. I'm waiting for answers from Rigol...
I'll let you know if I get any answers.
phamthai2503 do you use the same scope?
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #139 on: November 27, 2022, 11:30:04 am »
  I haven't bought it yet bro
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #140 on: November 27, 2022, 02:43:25 pm »
phanthai2503, for the use I make of my oscilloscope and if I had to buy one, I would take a Siglent SDS1x04X-E. It is more expensive but...
I'm sure the DS1102Z-E is fine for some uses but not for me, especially when the signal frequency exceeds the BF
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #141 on: November 27, 2022, 07:53:57 pm »
... especially when the signal frequency exceeds the BF
could you explain here?
  • Country: vn
Re: RIGOL DS1102Z-E
« Reply #142 on: December 01, 2022, 04:10:46 pm »
When I found out about Signent, last week's price was very good
Siglent SDS1104X-E      375$ 1 week ago (Black Friday), today 468$
Siglent SDS1202X-E      352$ 1 week ago (Black Friday), today 440$
Siglent SDS1104X-U                                                     today 383$
Siglent SDS1102CML+   330$ 1 week ago (Black Friday), today 365$
« Last Edit: December 02, 2022, 07:48:14 am by phamthai2503 »
Offline Piton
  • Country: ua
Re: RIGOL DS1102Z-E
« Reply #143 on: December 02, 2022, 07:30:41 am »
I bought mine Rigol for $274. Now it costs $329 in this store plus $69 shipping to Ukraine.
« Last Edit: December 02, 2022, 08:00:12 am by Piton »
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #144 on: December 03, 2022, 03:57:15 am »
Mysterious price increase.)  What is it motivated by?  Usually certain things lose their value over time, but here there is some kind of anomaly. My ds1102z-e also cost me $329, however, there was free shipping.
« Last Edit: December 03, 2022, 07:30:41 am by trmntr »
Offline nightfire
Re: RIGOL DS1102Z-E
« Reply #145 on: December 03, 2022, 11:41:34 am »
I got mine as it was introduced to the market for around 250 € via Amazon in germany. This was at the begin of the whole Covid story- nowadays, after some supply chain disruptions and proces of energy going up, the same article suffers from inflation and stuff...
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #146 on: December 07, 2022, 10:46:19 am »
BF means low frequency (LF)
Regarding trace flashing, Rigol changed the motherboard but can't solve the brightness problem with the time base at 5ns.
Rigol took back my oscilloscope.
Offline trmntr
  • Country: by
  • nice vibe
Re: RIGOL DS1102Z-E
« Reply #147 on: December 08, 2022, 09:21:24 am »
Was the money returned?  What are you taking instead?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: RIGOL DS1102Z-E
« Reply #148 on: December 09, 2022, 03:47:52 am »
I don't see such dramatic flickering on my DS1202Z-E (the 200MHz version)
Offline PatrickB
Re: RIGOL DS1102Z-E
« Reply #149 on: December 09, 2022, 04:11:46 pm »
trmntr:
Yes, Rigal refunded me the full purchase price.
I will buy a Siglent, the SDS1104X-E or SDS1204X-E. I don't really need the 200MHz. I have not found similar models, which suit me, in the Rigol range.
These 2 models are more expensive than the Rigol.
But Santa Claus is coming soon, I am thinking.
rsjsouza:
The flickering/flickering of the traces was, according to Rigol, an electronic failure.
Fortunately, this failure does not occur on the entire DS1x02Z-E range.
I had no luck with this failure but what prompted me to return my oscilloscope was the loss of luminosity with the time base at 5ns.
I still think that the DS1x02Z-E range is a good entry level at a very correct price, content of the possibilities of this device and that it is suitable for many users. Unfortunately for the use that I have, this defect is very annoying for me.
The following users thanked this post: rsjsouza, trmntr, phamthai2503
