.. are you spammer from Siglent or gwInstek guy?
Why in Poland they still sell this "buggy" version?
Why should them stop selling those models in Poland, if they don't assume the fault, and keep selling in other countries? Why is Poland special?
Apply the hack to upgrade trial options to Official and see the magic. Board version will change from 0.1.1. to 0.2.3 from time to time.
Now imagine what a piece of junk is inside this scope. Use the scope with time base bigger than 1 sec and it will take ages to refresh the screen.
Thanks God I sold mine but I feel sad about new owner, maybe he will use it just as a decoration inside his lab
Avoid this scope
While the scope itself is not bad, it has two major deficiencies for anyone wanting some serious work
1) The date in it cannot be changed. As crazy as it sounds in 2015..... it has a default date of December 31, 1969 at 4:00 PM and every single one of the saved files will have exactly the same date and time stamp. Imagine having a few days worth of data that no longer can be correlated to the conditions you were experimenting with
2) The file saving process is borderline useless. Sometimes it picks it's own names. overwrites data files etc. It can take 3 to 4 minutes to enter a name. The file saving system is likely based on DOS software and feels like it is indeed from 1969 like the permanent date stamp in the system
3) The voltage scale that you put prior to taking a reading has a tremendous influence on the actual reading. For example, if you had it at 100 mV per division and you were reading something in the 1-3 V region, you will definitely get the wrong reading (drastically different). If you are one scale away, then it is able to adjust in time. ie if you had it in the 500 mV per division and reading something in the single digit, then it will scale accordingly and you get more real data. What this means is that most times, you have to take the data twice to confirm you have real data
In any case, knowing what I know now, I would definitely keep looking for another brand. The thing that irritates me the most is that they gloat about having 20 M of memory when in reality this memory is borderline useless. I would rather have 1 M of memory that is useable that 20M that is useless
BUYER BEWARE!!!! Don't make the mistake I made and regret it
You have no idea how DSOs work, don't know how to use them, nor did you do your research on the product. You should remove this review because it's got no bearing on the quality of the product.
It doesn't have a real-time clock, nor does it claim to. The files don't have timestamps at all: The file creation timestamp you're seeing is the beginning of the UNIX date epoch (1/1/1970 at midnight), adjusted for the time zone and DST status of your computer.
The sample memory isn't for long-term logging, it's for pre- and post-trigger review of a signal.
The vertical scale absolutely has an effect on measurement, since that sets the gain of the input amplifiers, so if you set a low range and then measure a signal that exceeds the range, it will clip. Every oscilloscope works this way. Most DSOs (including this one) use 8-bit sampling, which means just 256 signal levels. Consequently, it's essential that the input range matches the signal you're looking at. If the 256 levels had a fixed mapping to the maximum input range (10V/div, 8 divs vertical, so 800V peak-to-peak), so that it never clips, it would only be able to resolve 3V steps, regardless of range.
So what is the current status of the Freeze Bug and the Math Bug ?
Did Rigol acknowledge them?
Did the latest software update fix them?
If "not" - when is the next version due ?
There does not appear to be any way for the user to update the Boot Version -- that I know of. I have asked Rigol USA several times about this but never got a real answer.
Yet there was at least one firmware release with a boot update and instructions on how to do it. Perhaps there is one specific firmware version out there that would allow an update.
Measurements Fail bug: I reported this to Rigol USA as soon as I found it, and they were able to reproduce it immediately on their scopes. This one seems to have been introduced by the update to latest firmware SP2; at least I never noticed it on earlier versions. It may also be related to Boot Version 0.0.1.3.
I have boot version 0.0.1.2 and I can reproduce this bug. So it looks loke it's not boot-related for me.
Firmware v00.04.04.00.07 no more freeze up bug
Before update
Nothing connected to inputs and persistence on any setting than min would freeze up scope when horizontal zoom enabled
After update
Any persistence setting and horizontal zoom enabled works now
Well... it's nice to know that this "hardware bug" is finally fixed for early Boot Versions, with a software update.
Before update
After update
Model DS1104Z(1054Z enabled all options)
SW 00.04.04.00.07
Board version 0.2.1
Boot version 0.0.1.2
FW 0.2.3.11
CPLD Version 1.1
Model | DS1104Z |
SN | (ommitted) |
Software Version | 00.04.03.02.03 |
Board Version | 0.1.4 |
Boot Version | 0.0.1.4 |
Firmware Version | 0.2.3.11 |
CPLD Version | 1.1 |
Build Date | Sep 11 2015 09:42:... (ommitted) |
F:\zscan\original\RIGOL\DS1000\DS1000Z-00_04_04_01_01\DS1000ZUpdate_NAND.GEL / CRC32: 4C2EF338
00000000 - File Type: DS1000Z
00000010 - Software Branch/Version: 00.04.04.01.01
00000020 - Bitmask: 00000F00
00000024 - # Sections: 11
Offset Section Name SectiSz StartAdr CRC32 Type
00000028 /sys/SparrowAPP.out 00107791 000002BC 865DD4FE 00000001 [000002BC-00107A4C] CRC OK
00000064 /sys/SparrowFPGA.hex 000C4372 00107A4D C72D7DD0 00000005 [00107A4D-001CBDBE] CRC OK
000000A0 /sys/SparrowDGFPGA.hex 00046F04 001CBDBF AD60366F 00000006 [001CBDBF-00212CC2] CRC OK
000000DC /sys/SparrowBootloader.sb 000503B0 00212CC3 E62EF3EE 00000008 [00212CC3-00263072] CRC OK
00000118 /sys/logo.hex 000BB818 00263073 1F2E52B7 0000000A [00263073-0031E88A] CRC OK
00000154 /sys/guiResData.hex 000B6B34 0031E88B 9C2E4FC0 0000000C [0031E88B-003D53BE] CRC OK
00000190 /sys/guiPicData.hex 0001E6BF 003D53BF 10D74A0D 00000011 [003D53BF-003F3A7D] CRC OK
000001CC /sys/SparrowConfig.hex 000BB818 003F3A7E 09D39C43 00000010 [003F3A7E-004AF295] CRC OK
00000208 /sys/SparrowWaveTable.hex 000020E8 004AF296 B1CE7C07 0000000B [004AF296-004B137D] CRC OK
00000244 /sys/SparrowCalFile.hex 00022EFD 004B137E 91673CA7 0000000F [004B137E-004D427A] CRC OK
00000280 00000118 004D427B 00000000 00000032 [004D427B-004D4392]
Offset CRC32 Flags Filesize Endianes Branch/Version
000002BC 82AC1341 00000003 00107779 AA5555AA 00.04.04.01.01 [000002D4-00107A4C] CRC OK
00107A4D C9AF5D56 00000000 000C435A AA5555AA 00.04.04.01.01 [00107A65-001CBDBE] CRC OK
001CBDBF 138E13B9 00000000 00046EEC AA5555AA 00.04.04.01.01 [001CBDD7-00212CC2] CRC OK
00212CC3 -------- -------- -------- -------- -------------- [00212CC3-00263072]
*** Bootloader Header ***
00212CC3 Header SHA-1: 49D6C3738FA6FD2AE905AAF7E090E7EF79BA5463 [00212CD7-00212D22] HASH OK
00212CD7 Signature 1: STMP MAGIC OK
00212CDB Format Version: 1.1
00212CDD Flags: 0x0000
00212CDF Image Size: 000503B0
00212CE3 1st Boot Tag Offset: 00212D53
00212CE7 1st Boot Section ID:
00212CEB # Encryption Keys: 1
00212CED Key Dictionary Start: 00212D33
00212CEF Header Size: 00000060
00212CF1 # Section Headers: 1
00212CF3 Section Header Size: 16 bytes
00212CF5 Random Padding: 0x5EBD
00212CF7 Signature 2: sgtl (Sigmatel?)
00212CFB Creation Time: 27-04-2015 14:28:39
00212D03 Product Version: 999.999.999
00212D0F Component Version: 999.999.999
00212D1B Drive Tag: 0x0000
00212D1D Random Padding: 0x8F9A3D11874A
*** Sections Table ***
00212D23 ID: | Ofs: 00212D63 | Len: 000502F0 | Flg: 00000001 - ROM_SECTION_BOOTABLE
*** Key Dictionary ***
00212D33 OTP Key0 Hash: DB4E7528C0F9A5207DD91E755303EC2B CBC-MAC_AES OK
*** Session Key (decrypted) ***
00212D43 Key: 46A9672A461903686222309F13ED6302 (using OTP Key0)
*** Sections (decrypted) ***
00212D53 TAG | 0001 | Sect ID: | Len: 000502F0 | Flg: 00000001 - ROM_SECTION_BOOTABLE
00212D63 LOAD | 0000 | Adr: 00000000 | Len: 0000003C | CRC: 408DF430 CRC OK
00212DB3 LOAD | 0000 | Adr: 00000400 | Len: 00003548 | CRC: DAE63C06 CRC OK
00216313 FILL | 0000 | Adr: 00018000 | Len: 00000960 | Ptn: 00000000
00216323 LOAD | 0000 | Adr: 00008000 | Len: 00000020 | CRC: 4D3C6D73 CRC OK
00216353 CALL | 0001 | Adr: 00008000 | Len: 00000000 | Arg: 00000000
00216363 LOAD | 0000 | Adr: 00000000 | Len: 00000040 | CRC: A9978A44 CRC OK
002163B3 FILL | 0000 | Adr: 00007FFC | Len: 00000004 | Ptn: 00000000
002163C3 LOAD | 0000 | Adr: 41000000 | Len: 0004CC10 | CRC: 2AE4A733 CRC OK
00262FE3 FILL | 0000 | Adr: 41300000 | Len: 00001900 | Ptn: 00000000
00262FF3 FILL | 0000 | Adr: 41301900 | Len: 00003B44 | Ptn: 00000000
00263003 FILL | 0000 | Adr: 41900000 | Len: 00300000 | Ptn: 00000000
00263013 LOAD | 0000 | Adr: 00008000 | Len: 00000020 | CRC: DF5BA493 CRC OK
00263043 JUMP | 0001 | Adr: 00008000 | Len: 00000000 | Arg: 00000000
*** File SHA-1 Hash (decrypted) ***
00263053 File SHA-1: C0274B0B57C7687849AB8D042F3E3C23142D9D42 [00212CC3-00263052] HASH OK
Block Processed OK
00263073 9B4EA177 00000000 000BB800 AA5555AA 00.04.04.01.01 [0026308B-0031E88A] CRC OK
0031E88B 271E3AB5 00000000 000B6B1C AA5555AA 00.04.04.01.01 [0031E8A3-003D53BE] CRC OK
003D53BF 01873014 00000001 0001E6A7 AA5555AA 00.04.04.01.01 [003D53D7-003F3A7D] CRC OK
003F3A7E 5DEF7058 00000000 000BB800 AA5555AA 00.04.04.01.01 [003F3A96-004AF295] CRC OK
004AF296 27F4C06F 00000000 000020D0 AA5555AA 00.04.04.01.01 [004AF2AE-004B137D] CRC OK
004B137E 1E61A8F6 00000000 00022EE5 AA5555AA 00.04.04.01.01 [004B1396-004D427A] CRC OK
File Processed OK
