I am currently renovating several PTS1000 signal generators, and they use 50 (fifty) Bourns 3299 trimmers for coarse setting of VCO
Now the 3299-serise seems to be a lot more expensive and harder to find (at least "my" values) vs the 3296-series
Reading data sheets, it seems it is a drop-in replacement as the only difference seems to be a thinner housing on the 3296. But is there any advantage to keep looking for 3299-potentiometers? Key parameters are noise and keeping performance over time.
I rather do this right the first time. Not too fun replacing 50 pots.... on ten units. Leave the math for the reader
Should add: The PTS1000 comes with the 3299.. hence the query
