Greetings,I want to buy an oscilloscope and I am between the following two:Rigol DS1052ELeCroy WaveAce 101 Any opinions?Thanks
2013-03-26The Notice of Siglent SDS1000 series stop production Dear honored partners,Thanks very much for your support and attention to Siglent all the way along. As SDS1000L series, with 7" LCD display and higher cost performance, have been launched, we would like to notice you that Siglent will stop manufacturing SDS1000C/D/CM/CN/CF/CE with 5.7" LCD display after 30th April, 2013.SIGLENT TECHNOLOGIES CO., LTDMarch. 2013
Agilent DSOX2000 series has high resolution mode. It should be in your table.
LeCroy WaveAce series is a rebranded Siglent. Compare attached pictures. The button layout is exactly the same!!
QuoteLeCroy WaveAce series is a rebranded Siglent. Compare attached pictures. The button layout is exactly the same!!Yes, the buttons, psu etc are very much alike. But if you look at the bottom PCB the LeCroy has a very big black mulipin IC (fpga ? ) and the Atten has one that is about 1/4th of that size. So they share the cabinet and psu but the heart of the scopes are different. So I would not call that rebranded. It is made by Atten or siglent but it looks like it is not a just a rebranded copy. I think a brand like Agilent or LeCroy has enough knowledge to give them a design or make mods according there wishes. Maybe better parts. They do not have to make it dead cheep and so it just last the warranty periode, It must be good enough not to trow away there name with customers also buying there more expensive products and give support/service. Even a lot of components from China are fake but many here are the first to write that when two scopes have the same cabinets, that they are thus totally the same and it is no use to buy the A-brand.
