Except for the issue with compensation range identified by edavid, they will work fine at 100MHz or even higher.
At 400MHz however, the fixed high frequency compensation might not be right for a 400MHz or higher oscilloscope as it was designed for the 400MHz models of the 2465 series. A slower oscilloscope will not show this problem.
