V2.2.3.1 has the following issues:
- If I start out with Long Memory Capture it works.
- If I then switch to Realtime waveform, no waveform is shown on the screen (but it does update, the graticules jump in some out-ranging mode?)
- Screenshot still does not work.
- If I then go back to Long Memory Capture the program locks up and I need to force-close it
This is weird. Here is what I have compared to yours:
- I tried starting in Long Memory Capture and it worked just once, subsequent capture does not work displaying just the blank waveform/FFT windows.
- If I then switch to Realtime waveform, I can capture static waveform and its FFT, no real time update. Every time I cycle the capture button it grabs a static picture, and the scope screen flickers and says "Invalid data"
- If I then switch to Screenshot Capture, I can capture screens no problem each time I press the capture button
I also noticed in Real Time capture the FFT displays different spectrum depending on the timescale, which makes me think it is incorrectly calculated or the waveform data it is using is invalid. I have attached 3 screenshots of a same 100MHz signal with different timescale, you can see they all show different FFT data.
