Author Topic: Siglent SDS1052DL+ / SDS1102CML+ hack  (Read 26966 times)
Offline tv84
  • Country: pt
Re: Siglent SDS1052DL+ / SDS1102CML+ hack
« Reply #75 on: September 01, 2020, 04:33:25 pm »
So, basically, the language menu is as attached.
Copying the original config back to both locations brought the model number back and forced Chinese language.
That is great news!
Later, I'll share a few more .CFG to see their behavior.
Offline tv84
  • Country: pt
« Reply #76 on: September 01, 2020, 06:53:41 pm »
Test this one, please.
Offline PiXEL8
« Reply #77 on: September 01, 2020, 07:16:33 pm »
No change, still model SDS1202F+ and forced Chinese language.
Offline Chris Roubis
  • Chris Roubis
« Reply #78 on: October 05, 2020, 01:53:27 am »
Don't worry... Tv84 will eventually sort it out for you.
Electricians have longer fuses
Offline Lama12
« Reply #79 on: October 06, 2020, 10:52:23 am »
Hi, I just ordered an SDS1072CML +. Will anyone still have information on how to convert it to SDS1152CML +.
Could you please kindly send me a PM how you did it.
Thank you in advance.
Offline tv84
  • Country: pt
Re: Siglent SDS1052DL+/SDS1102CML+ hack
« Reply #80 on: December 30, 2020, 09:05:53 pm »
Thank you Tautech and rf-loop.  This confirms my assumption, so me and my friend did some work.  The result is  pleasing.
This is verified on SDS1102CML+ with FW version  6.01.01.21R2 and SDS1052DL+ with FW version 6.02.01.10R2.
The trick is the same.
1) Input below command in a Notepad file and rename the file as startup.sh
#! /bin/sh
telnetd
Offline quinty
« Reply #81 on: January 28, 2021, 01:44:50 pm »
SDS1072CML+ with FW version  6.01.01.21R2 confirmed, works like a treat.
Is anybody has problems with file coding then use file from " Reply #80".
Lama12, użyj załączonego pliczku, jak sam robiłem plik to nie działało. Telnet na porcie 23.
Offline JTRACKER
« Reply #82 on: February 02, 2021, 10:04:20 pm »
I know it's been a while, but can I ask what SCPI command was executed, to get the 1152 from the 1052?
Thanks
Offline tv84
  • Country: pt
« Reply #83 on: February 03, 2021, 10:02:30 am »
It's the usual command to change BW:
MCBD <BW_lic>
The following users thanked this post: oz2cpu
Offline Raima010
« Reply #84 on: March 18, 2021, 05:49:57 pm »
Wondering if someone have experience hacking SDS1102X+ oscilloscopes. All backdoors are closed to read memdump. Scope has ID xxxx.yyyy.zzzz so missing last 4 numbers. Tried some code calculators from forum which give some unlock codes with only 12 digits input but none of them work.
Some way to read memdump with disassembly? Other ideas?
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #85 on: November 28, 2021, 06:02:00 pm »
sorry to kick this thread alive again..
but I find no other threads about SDS1102CML hack
new trick : i was not able to connect via putty, correct ip number, tribble checked it was corrent,
none of the mentionened ports, SSH or telnet, no way. also checked with nmap where they could be..
The solution : get siglent software EasyScopeX
this will connect to the scope just fine,
its command interface also accept the hack code, and you can up the bandwidth that way
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline Toolworker
« Reply #86 on: December 18, 2021, 02:31:45 am »
I can connect to my SDS1102CML+ on the LAN with EasyScopeX, and ping it, but can not Telnet to it even after rebooting with startup.sh on the USB drive, or bring up the IP address in a browser.
The firmware version is 6.01.01.22, the 8/6/21 update.
Any suggestions?
« Reply #87 on: December 18, 2021, 03:01:48 am »
Any suggestions?
Check item #4 on P13 of the programming guide:
https://siglentna.com/wp-content/uploads/dlm_uploads/2021/01/SDS1000-SeriesSDS2000XSDS2000X-E_ProgrammingGuide_PG01-E02D.pdf
Offline Toolworker
« Reply #88 on: December 18, 2021, 04:43:23 am »
Thanks. But that just opens an SCPI command processor, which can also be done with EasyScopeX through a LAN or USB connection.
After trying a couple of USB drives with startup.sh, I was finally able to telnet to a Linux login prompt with one of the drives.
« Reply #89 on: December 18, 2021, 06:23:13 am »
Oh, sorry. I knew some instruments need to have a port specified for access and believed 5024 was open for CML+. Then I found this:
https://siglentna.com/operating-tip/instrument-socket-and-telnet-port-information/
Offline razer.zt
  • Country: ua
« Reply #90 on: February 02, 2022, 02:00:44 am »
Hello
I need help.
My device 2190e (sds1152cml+) was fully erased.
Attention !!! Don't run "run mmc-all" from uboot. This command contains "run chip.erase"!!! This will fully erase nand .
Factory partitions with calibration data was erased too.
Who can share partitions from working device.
For now the device is not usable.
Thank you for help.
Offline makersLabs
« Reply #91 on: July 17, 2022, 11:52:48 am »
I have a SDS1122E+ from SIGLENT
My version was in Chinese only, I would appreciate changing to English
I try to DL from their website  here : https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1000CML+_6.01.01.21R2_EN.zip
I finally succeed to flash BUT I cannot change to anything else than Chinese  :-(
How to change this and access to language options other than only Chinese?
Rgds
« Last Edit: July 17, 2022, 03:09:51 pm by makersLabs »
